09-23-2007, 05:27 PM
1996 25' Excella
Tallahassee
Wheel comes off ground or lack of axle movement
Did not really know what to title this thread but the wheel does come off the ground. What I am referring to is that when I back my trailer into my driveway, one of the wheels (25 ft dual axle) comes off the gound. I have a fairly significant dip at the end of my driveway. Driveway goes down hill and the dip is right at the end where it meets the road. I have to make a pretty tight turn, backing into the driveway and this turn in conjuction with the dip causes some wheel lifting and axle gyrations. I go slow, but just wanted to make sure I am not putting such undo stress on the suspension etc. that will cause problems. Any thoughts will be appreciated.
09-23-2007, 05:44 PM
GLASS GODDESS
2011 22' Sport
Greenville
, South Carolina
Hi there, I never noticed that the front axel wheels do go off the ground too, however..I just replaced both tiresb and wheels and was thinking perhas that the new lbs. (65 vs. 45) might have made the difference...I notice this when going over dips and such, speed is not the issue...what say all?
09-23-2007, 05:46 PM
418
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley
That's fine.
That's also another reason Airstream specifies 2600lb capacity wheels for their trailers. Wheels come off the ground more often than we realize. Just about every driveway, gas station entrance, drainage dip, etc, unloads partially or completely at least one of the wheels on our dual axle trailers.
No worries, just take it slow. Wheels coming off the ground, and tight turns, are often accompanied by creaking and groaning noises...all normal.
09-23-2007, 06:00 PM
GLASS GODDESS
2011 22' Sport
Greenville
, South Carolina
Thanks for the wisdom! NICE TO KNOW!
09-23-2007, 06:05 PM
St. Cloud
Putting one wheel at a different level (wheel ramp) is a valid way of changing tires! See http://www.airforums.com/forums/f457...amp-35996.html. When given pineapples, make mai tais!
418
1974 29' Ambassador
Yucca Valley
Can you elaborate on this a bit?
I am assuning you're talking tire pressure?
Is your trailer dual axle? If so, did you replace all tires and wheels, or just two? Or did you mean both tires and wheels as a whole? Confused....as usual.
09-23-2007, 06:17 PM
GLASS GODDESS
2011 22' Sport
Greenville
, South Carolina
Sorry, yes I replaced al for wheels and tires w/ aluminum wheels and a nice light truck tire rated at 65 psi. tThis is when I noticed the lifting. The original wheels and older tires were on my 66' overlander
More than one rivet loose
Los Alamos
, New Mexico
Can you provide a picture?
Michelle TAC MT-0
Sarah, Snowball
09-23-2007, 06:20 PM
Retired.
, At Large
The only time you would have a problem is if the bumper drags. If it does, stop immediately, and reposition your rig before trying again.
09-23-2007, 06:44 PM
2002 25' Safari
Dewey
I notice when I pull out of the driveway onto the street that the front tires are off of the ground untill the rears come off of the driveway. It is no big deal. I sometimes will hit the brakes when the wheel is off the ground, just to watch it stop.
Richard
09-23-2007, 06:51 PM
Retired.
, At Large
I guess that's one way to verify your brakes are working.
09-24-2007, 06:16 AM
1996 25' Excella
Tallahassee
Appreciate the replies. Sounds like nothing major to worry about. My driveway is similar to the picture of axflycaster's picture, only mine is quite a bit steeper. Thanks again for the responses.
Richard
