Old 07-19-2007, 07:06 AM   #1
Sky
Classic 30
Sky's Avatar
Sum Wear , Ohio
Wheel bearings on 2007 classic?
Is it true the wheel bearings on 2007 classics, with Dexter running gear, are sealed and do not need to be repacked each year?
Dale
"Only dull people are brilliant at breakfast" - Oscar Wilde
2500HD DMax............30' Classic
Sky is offline   Reply With Quote
Old 07-19-2007, 08:35 AM   #2
Dale
The Classic's have sealed bearings.
All other models have standard type bearings.
The hub and drums on the classics should still be pulled every 10,000 miles to inspect the brakes, for wear, or broken parts.
Sealed bearings setups have a tendency to cause owners to ignore the electric brakes.
Not a good idea.
Old 07-19-2007, 11:47 AM   #3
_
the new classics also have disc brakes so there is no drum to inspect.
the rotors and pads and calipers can be checked easily by removing the wheel.
the 'nevr lube' bearing pack is warranted for up to 100k miles.
and while it isn't serviceable, 'sealed' is a relative term.
i'd still be cautious about submerging a wheel/bearing pack in water....
cheers
2air'
Old 07-19-2007, 06:36 PM   #4
Sky
Classic 30
Sky's Avatar
Sum Wear , Ohio
Thanks Andy and 2Air, I appreciate the info.
Dale
Old 07-19-2007, 07:42 PM   #5
2005 34' Classic
Richmond , Virginia
What year did they start putting sealed bearings in?
Resorts is offline   Reply With Quote
Old 07-20-2007, 04:57 AM   #6
2005 34' Classic
Richmond , Virginia
Are the sealed bearings only on the classics with disk brakes or did they come on the drums too?
Old 07-20-2007, 11:26 AM   #7
_
hi resorts
changes like the nev r lube bearings often happen mid year or near the end of a model run...
so exact dates of 'change over' are hard to find.
the 07/08s have the 100k bearings...
NONE of the 05 classic units do.
the change from drums to disc brakes was march/april 05, the last 3 months of the model year.
most of the 05s don't have dexter axles, they have henschens.
henschens doesn't offer a sealed bearing pack...
and it's my understanding, the dexter bearings don't fit on henschens axles.
dexter's nev r lube bearings CAN be used with drum brakes on these new dexter axles..
try the search function, most issues already have useful info posted...
http://www.airforums.com/forums/f437...sic-30396.html
http://www.airforums.com/forums/f437...ngs-25007.html
unless your unit has been altered, it has henschens axles, but there is a tag/marker on the axles with this info,
and your owners packet should even contain the serial numbers for the axles.
alternatively email a/s tech support with your vin number and get the correct info.
cheers
2air'
Old 07-24-2007, 05:23 PM   #8
Somewhere , Indiana
Right on!
cheers
2air'
This is 100% correct!
That is the greatest limitation of the Nev-R-lube system.
Regards,
Henry
axleman is offline   Reply With Quote
Old 07-24-2007, 06:07 PM   #9
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
Well, one would hope that you'd never submerge your Airstream in water!
Old 07-24-2007, 06:59 PM   #10
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
My 06 Classic has the never lube sealed bearings with disk brakes. Did they go back to drums for the 07s?
Michelle TAC MT-0
Sarah, Snowball
Old 07-24-2007, 08:19 PM   #11
Sky
Classic 30
Sky's Avatar
Sum Wear , Ohio
No, my 2007 Classic has hydraulic disc breaks.
Old 07-24-2007, 09:43 PM   #12
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Dumb Question # 1
Hi, how would anyone know if you have 100 miles or 100,000 miles on your trailer? Or where is the Black Box hidden on our trailers? Maybe it should be 10 years or lifetime. Is that estimated life or warranty? [100K Bearings]
Maybe that was three dumb questions!
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 07-24-2007, 10:07 PM   #13
_
Originally Posted by ROBERTSUNRUS
Hi, how would anyone know if you have 100 miles or 100,000 miles on your trailer?...Maybe it should be 10 years or lifetime. Is that estimated life or warranty? [100K Bearings]
hi bob
warranted for up to 100k...
from the dexter site....
5yrs/100k
Dexter Axle - Trailer Axles and Running Gear Components - Nev-R-Lube Bearings
i agree unless we install mile meters who would know distance?
for airstream specific owners the warranty used to state that the bearings MUST be initially inspected at 6 months or the warranty is void.
this was until the switch to dexter/nev r lube.
so i don't know how the current fine print reads...
dexter has a very complete website with install instructions, warranty info, service manuals, parts and so on....
i like the henschen/kodiak/actibrake hat trick!
fwiw, the dexter axle/nev-r lube set up cannot be retro fitted to pre '06 classics without modification to the frame/mounting brackets...
cheers
2air'
Old 07-24-2007, 10:40 PM   #14
hi bob
5yrs/100k
cheers
2air'
When you fly an airplane, you must always keep two logs. One for the engine/engines and one for the airframe. So I was well trained.
During my towing years, I always kept a towing log book in the glove compartment of the TV.
I would list the date and the miles for that date, the beginning location and the ending location for that date as well. That made weekly, monthly and yearly totals, a piece of cake, as well knowing where I had been and when.
All you need is a small spirel notebook. Costs maybe 50 cents.
My boss loved it.
Certainly far superior to a hubometer.
Safari VS. Classic Questions kkrogh Our Community 24 12-20-2005 11:10 AM
repacking the Wheel Bearings Chuck Axles 26 04-27-2003 08:59 PM
Replace Wheel Bearings? Pick Axles 6 02-28-2003 06:30 PM
Wheel Bearing?? - - or - - Brakes?? overlander64 Axles 8 11-24-2002 12:13 AM
Wheel Hub Temperature 74Tradewind Axles 4 07-23-2002 07:26 PM
