Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Axles
Old 12-20-2003, 12:10 PM   #1
AV8
AV8's Avatar
Profile:
Wheel Bearings for a 74 overlander
I have just recently purchased a 1974 Overlander in Florida. We live in NH and are going down after Christmas to pick it up. I would like to replace / repack the bearings prior to the return trip. I am unsure about the exact size of the bearing and seals. All I have for information is a 73 service manual, I don’t know if there were any changes in 74. The 73 manual has outer bearings LM67048, inner 25580, and a seal of 42385. This seems to correspond to the following kit # BK3-300, from the following link:
http://www.lowcosttrailersupplies.co...egory_Code=WBK
All I have for information is a 73 service manual; I don’t know if there were any changes in 74. Can anyone confirm that this kit will work, and/or if there were any changes from 73 to 74?
AV8 is offline   Reply With Quote
Old 12-20-2003, 02:16 PM   #2
Navigator
Profile:
Congratulations on the purchase of your new Airstream.
May I suggest that you bring a little test light with you so that you can verify that the trailers umbellical cord will be wired correctly to your tow vehicle.
Dick
Navigator is offline   Reply With Quote
Old 12-20-2003, 02:32 PM   #3
AV8
AV8's Avatar
Profile:
Thanks for the advice, I have actually been down there when I closed the deal. The trailer has an “Airstream” connector with round plugs, so I have a new 7way cable to replace the old one. That and soldering irons, multi meter, etc. etc...
The bearings might only need to be repacked, but the price of these kits seemed reasonable enough to just go ahead and replace the whole lot. This summer we will be putting just shy of 10k miles on it, so it would not be a wasted investment…
Old 12-20-2003, 07:21 PM   #4
markdoane
Profile:  , Minnesota
Images: 59
AV8:
I bought the same kit from LCTS and it seems fine. This is a common kit for Dexter and Reliable axles (and I assume Henchens also).
Good luck and take plenty of paper towels.
Old 02-02-2004, 06:08 PM   #5
dreamqueen
Profile:
Question wheel bearing& seal kit
Greetings; I just joined this forum. Can you please advise me as to where I can purchase wheel bearing & seal kits for our '66 Tradewind? It has double axles; has been sitting for nearly 10 years with only one move last year. Purpose of bearing and seal replacement is to prepare it to tow it to the nearest Airstream service center (a 60 mile trip) for a safety check and some minor repairs of the plumbing.
Thanks!
Beth
dreamqueen is offline   Reply With Quote
Old 02-03-2004, 10:42 AM   #6
Inland RV Center, In
Commercial Vendor
Profile:  Corona , California
Beth.
Have your dealer also check your axles.
They can and do go bad when the trailer has sat for years.
Or, you can check them out yourself. Go to our web site http://inlandrv.com
Click on articles and then go to the Dura-torque axle article.
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
Cooking Forum - Sailing Forum - Early Retirement
Airstream Trailer Forum - Aquarium & Reef Forum
Royal Forum - Book and Reader Forum - Yoga Forum
Volkswagen Touareg Forum - Jeep Wrangler Forum
Whitewater Kayaking & Rafting Forum - Yoga Forum
Interference - U2, Pop Culture & Social Responsibility
