Old 10-30-2007, 04:34 PM   #1
2007 25' Safari FB SE
Evergreen , Colorado
Question Wheel bearings
How often should you pack your AS wheel bearings? I have been told every year/every 5000 miles/every3to 5 years or 12000 miles which comes first.
Allen H is offline   Reply With Quote
Old 10-30-2007, 04:42 PM   #2
1994 30' Excella
Mississauga , Ontario
Hi,
My gut feeling is to do them as often as you would on a car. That is usually when a brake job is done. That would be every 40 to 80 thousand miles.
However you are not likely to put that kind of mileage on the average trailer so I do mine every three years max. It's also a good idea to check the brakes.
Al
Old 10-30-2007, 05:50 PM   #3
Wheel bearings should be repack and the grease seals replaced every year or 10,000 miles, which ever comes first.
You cannot compare wheel bearing care on a travel trailer to a car.
A car is used every day, a trailer is not.
Cars cannot twist the tires like a trailer can.
Those are some of the reasons why a car-trailer comparison is impossible.
If you waited even to 25,000 miles, the brakes would be shot, along with the grease probably having much water in it.
Old 10-30-2007, 06:23 PM   #4
SilverCottage's Avatar
2007 27' Safari FB SE
LONDON , ON
Hey Andy, where do I get new wheel bearings for my 2007 27FB Safari? Does the local NAPA carry them?
Thanks.
SilverCottage is offline   Reply With Quote
Old 10-30-2007, 06:37 PM   #5
Exclamation Wheel bearings
Andy, Thanks for your reply, our trailer is 10 mo. from being new and we have aprox. 6900 mileas on it. We will be leaving on a trip in Feb. Do you think it is OK to put another 1100 miles on it befor I do the berings?
Old 10-30-2007, 07:24 PM   #6
Thanks.
NAPA stores should have them.
Make sure you get the numbers off the bearings that you have.
Old 10-30-2007, 07:27 PM   #7
Since your wheel bearings have never been serviced, I think it would be wise to repack them now, check out the brakes and adjust them correctly, and replace the grease seals.
It would also be wise to have the running gear balanced, but if not, ar least get the tires and wheels balanced.
Pushing safety, especially in the winter months, is not a good idea.
Old 10-30-2007, 08:03 PM   #8
silverleeper's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Images: 8
Maintainance
Hi Allen H, Take a look at this thread started by nickcrowhurst. It's a great read on trailer maintenance.
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Old 10-30-2007, 08:25 PM   #9
_
all opinions aside here is the most immediate issue for YOUR trailer...
the warranty on your unit includes a clear mandate.
the wheel bearings MUST be inspected during the first 6 months of ownership, or about 5 k miles which ever comes first.
IF you haven't done this first check yet (at 10 months) that's a problem.
so coverage of hub/brake/wheel issues under warranty, may be a problem now.
beyond this very specific issue (which may be irrelevant now)
there are lots of schedules, but for a unit under WARRANTY do exactly as a/s suggests...
yearly/10k.
i tow 25,000 miles a year and do it yearly not every 10k, the grease has been reported to 'still look fresh' one time and 'starting to look dark' another...
the primary reason to inspect the hubs yearly is the brakes....
repacking the bearings while there makes good sense.
now let's suppose yearly is a tad too frequent but every 2 years is critical...
so a year passes and there are not issues, then 2 years pass and you can't remember IF you did them last year or not!
see the problem for most folks is extending beyond the recommended intervals usually gets extended again in multiples and too long.
people generally THINK they've done more than they actually have....
and more recently than they really have.
so when was that last prostate check? (see what i mean)
btw a/s is NOW using nev-r lube bearing packs on some models that are good for UP TO 100k miles, then replaced.
i've forgotten IF your unit has these bearings.
so follow the a/s guidelines for your unit.
cheers
2air'
Old 10-30-2007, 10:04 PM   #10
just jd.
5cats's Avatar
2007 20' Safari SE
San Diego , California
Dexter bearing cross reference
Bearing_CR.pdf
2007 20' Safari SE/LS // 12063 //CA-5// ("ex") 2916
5cats is offline   Reply With Quote
Old 10-30-2007, 10:06 PM   #11
just jd.
5cats's Avatar
2007 20' Safari SE
Dexter maintenance schedule
Maintenance_Schedule_2-07_72_res.pdf
Old 10-30-2007, 10:07 PM   #12
just jd.
5cats's Avatar
2007 20' Safari SE
Dexter replacement parts
Replacement_Parts___Kits_2-07_72_res.pdf
Old 10-30-2007, 10:08 PM   #13
just jd.
5cats's Avatar
2007 20' Safari SE
Dexter seal cross reference
Seal_CR.pdf
Old 10-30-2007, 10:28 PM   #14
C Johnson's Avatar
1965 17' Caravel
Butte , Montana
Images: 326
Send a message via MSN to C Johnson Send a message via Yahoo to C Johnson
cheers
2air'
That is something I WOULD remember
Bad analogy, lol.
I do the bearing check every two years. By then you should be looking at the brakes too anyway.
AIR # 7276, WBCCI # 7276
Photos of Project 2k5
Project 2k5
Life is a journey, not a destination
C Johnson is offline   Reply With Quote
Wheel bearings FlyingW Axles 3 07-01-2006 05:36 PM
Airstream Wheel Bearings Hunter_1 Member Introductions 15 04-18-2006 02:54 PM
Wheel Bearings 76ArgosyDave Axles 7 06-29-2005 03:00 PM
Wheel Bearings 85MH325 Axles 5 04-05-2004 06:41 AM
repacking the Wheel Bearings Chuck Axles 26 04-27-2003 08:59 PM
