Old 10-30-2007, 10:30 PM   #15
just jd.
5cats's Avatar
2007 20' Safari SE
San Diego , California
It just so happened that my camping plans fell through this last weekend, due to the wildfires, so I did the bearing repack on my Safari for the first time, instead. There are better, full pictorials on the subject elsewhere, so I only wanted to report a couple tips I ran into rather than the whole deal.
I agree with 2air' on doing the scheduled service during the warranty period, and also thought it a good idea to get familiar with the brakes. I'm glad I took the opportunity to get comfortable with jacking up my single axle rig and getting the wheels off, all in the comfort of my driveway, rather than during a roadside "event".
It was also an excellent opportunity to seal up all the seams and gaps in the wheel well cavities, before the winter travels get going -- as if it might actually rain around here someday.
Cheers,
-jd.
2007 20' Safari SE/LS // 12063 //CA-5// ("ex") 2916
5cats is offline   Reply With Quote
Old 10-30-2007, 11:41 PM   #16
2dabeach's Avatar
2007 25' Safari FB SE
North/East , New Jersey
Since your wheel bearings have never been serviced, I think it would be wise to repack them now, check out the brakes and adjust them correctly, and replace the grease seals.
It would also be wise to have the running gear balanced, but if not, ar least get the tires and wheels balanced.
Pushing safety, especially in the winter months, is not a good idea.
I saw you suggestion on "running gear balance" and "tire & wheel balance."
Q1 - I understand tire & wheel balance. What is running gear balance?
Q2 - Does Airstream balance the original equipment wheels/tires as part of their production process?
2007 Safari 25' FBSE LS
2006 GMC Sierra 2500HD Crew Cab 4WD Duramax
2dabeach is offline   Reply With Quote
Old 10-31-2007, 03:48 AM   #17
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
if there is any doubt on how often to check your bearings or brakes check this thread out!
http://www.airforums.com/forums/f44/...ure-37271.html
john
you call them ferrets, i call them weasels.
Old 10-31-2007, 05:20 AM   #18
SilverCottage's Avatar
2007 27' Safari FB SE
LONDON , ON
Originally Posted by 5cats
Thanks for the great photos and links to Dexter. Gives me something to get ready for when spring rolls around.
SilverCottage is offline   Reply With Quote
Old 10-31-2007, 04:12 PM   #19
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up All Of The Above!!
Un-wrap in Spring...remove drums, inspect/repair as needed!
Part of every spring ck-up
Name:	2007 WINTERIZE 002.jpg
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Wheel bearings FlyingW Axles 3 07-01-2006 05:36 PM
Airstream Wheel Bearings Hunter_1 Member Introductions 15 04-18-2006 02:54 PM
Wheel Bearings 76ArgosyDave Axles 7 06-29-2005 03:00 PM
Wheel Bearings 85MH325 Axles 5 04-05-2004 06:41 AM
repacking the Wheel Bearings Chuck Axles 26 04-27-2003 08:59 PM
