Old 06-06-2005, 06:23 AM   #1
round things are best!
76ArgosyDave's Avatar
Wheel Bearings
Hey,
I want to replace the wheel bearings on my 1976 argosy 26. Does anyone know the part numbers for these bearings or should I just take the tires off and order them after I take everything apart?
Dave
76ArgosyDave is offline   Reply With Quote
Old 06-06-2005, 08:38 AM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Originally Posted by 76ArgosyDave
Hey,
Dave
Dave, I don't have the numbers for the bearings, but the seal numbers are National #H73336550
You can take one wheel off, and the drum, and get the part numbers for inner and outer, then proceed with all the other wheels and tires.
Old 06-06-2005, 04:37 PM   #3
Bearings
76ArgosyDave
If your 76 has 12" brakes, the bearing numbers are, 25580 and LM67048.
If your trailer has 10" brakes, the bearing numbers are, L68149 and L44649.
The grease seal number depends on which size brakes you have.
Old 06-06-2005, 05:23 PM   #4
Well Preserved
1993 21' Sovereign
Use Andy's numbers. It is better to cross the numbers once, than to cross reference a number that has been cross-referenced already. There is less chance of errorrs.
Old 06-07-2005, 05:59 AM   #5
Thank you very much for the help!
I am going to call my bearing guy today LOL
Dave!
Old 06-29-2005, 02:45 PM   #6
1974 28' Argosy TT
stinkytwinky's Avatar
1975 28' Argosy 28
Hinsdale , New Hampshire
Send a message via Yahoo to stinkytwinky
Thumbs down Bearings and seals for a 1974 28' Argosy
Hey Andy here is another one for you. Do you know the part numbers for the titled bearings and seals (see the title). I have a twin axle set-up, and I have not had the badly dryrotted tires off yet to see what size drums I have. I hope you can come up with something from this lack of information. I will try to get a better grip on the sizes after the 4th weekend.
We have planned a long (4day) weekend over the 4th in Exeter, NH (near the Coast). I hope she makes it (squeal from the bearings?). She made it from HInsdale, NH to Rindge, NH (with a little squealing).
I cannot replace them until after (or during) the trip.
Could one use the bearing buddies on these axles?
1974 28' Argosy (Hey, Airstreams are just Argosy's that haven't been painted yet .. )
1999 Ford F250 Lariat SD Extended Cab with 7.3L Power Stroke Diesel
stinkytwinky is offline   Reply With Quote
Old 06-29-2005, 02:56 PM   #7
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
Originally Posted by stinkytwinky
..Could one use the bearing buddies on these axles?
No.
Tom
Old 06-29-2005, 03:00 PM   #8
Stinkytwinkie
If you have 10 inch brakes, your bearing numbers are L68149 and L44649.
The grease seal should be Airstreams part number 680377, 2.56" OD, 1.719"ID, double lipped.
Bearing buddies and the like are a no-no-no, ever. Best way in the world to screw up the brakes, if improperly used.
Wheel Chocks pjtaia On The Road... 13 10-28-2005 02:27 PM
repacking the Wheel Bearings Chuck Axles 26 04-27-2003 08:59 PM
Replace Wheel Bearings? Pick Axles 6 02-28-2003 06:30 PM
Wheel Bearing?? - - or - - Brakes?? overlander64 Axles 8 11-24-2002 12:13 AM
Wheel Hub Temperature 74Tradewind Axles 4 07-23-2002 07:26 PM
