Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Axles
Prev Previous Post   Next Post Next
Old 07-25-2002, 10:32 AM   #1
niftypkg's Avatar
Profile:  1971 27' Overlander
Cornville , Arizona
Unhappy Wheel Bearing seals!!!
Thought I knew it all!! Replacing seals using AS seals with a double lip! Which Way?? Thought all seals go with leading lip towards bearing to keep grease in ,the inner. That's the way I installed it. The other lip is V shaped I suppose to keep out dirt, the outter??? That lip has the exposed spring if you peel back the lip. Which way?? Be nice.
niftypkg is offline   Reply With Quote
Wheel Bearing Numbers Pick Axles 5 09-27-2004 06:46 PM
'66 Tradewind wheel bearing size? dreamqueen 1959-69 Tradewind 1 02-18-2004 07:13 PM
Wheel bearing part #s Ultradog Axles 6 05-17-2003 02:29 AM
Wheel Bearing?? - - or - - Brakes?? overlander64 Axles 8 11-24-2002 01:13 AM
Wheel Bearing Temperature Road Ruler Axles 23 10-16-2002 09:54 AM
