Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Axles
Old 09-01-2009, 11:39 AM   #1
Jabba's Avatar
Profile:  1955 30' Sovereign of the Road
, Michigan
Wheel Bearing Seal Lookup/interchange guide
While searching for replacement double lip wheel bearing seals for our 1955 Sovereign, I found this very handy search tool. Use the part lookup to find the dimensions of your current seal or use the interchange to look up other manufacturers part numbers and specs. I called my local auto parts store with no luck at first, after finding this site and entering the dimensions and finding the part number, I called back and they can order it. By shopping around I am saving @ $10 per seal. Hope someone finds this useful.
SKF Seals
Jason & Veronica Jablonski
S.E. Michigan
1955 Commodore Vanderbilt/Liner 30'
2008 Chevy Silverado Ext. Z71 w3.73
Jabba is offline   Reply With Quote
Old 09-01-2009, 08:56 PM   #2
Moderator dude
Action's Avatar
Profile:  1966 26' Overlander
Phoenix , Arizona
Images: 13
Thanks for sharing!
Action
1966 Mercury Park Lane 4 DR Breezeway 410 4V, C-6, 2.80 - towing a - 1966 Overlander International Twin Bed
1996 Lincoln Mark VIII Diamond Anniversary 4.6L (275hp), 4R70W - 1990 Ford E 150 5.8L, E4OD, 3.55 ____________________________________
Phoenix ~ Yeah it's hot however it's a dry heat!
Action is online now   Reply With Quote
Old 09-24-2009, 07:55 AM   #3
Jabba's Avatar
, Michigan
1950's bearing seal size
After much looking and shopping to get the price from $21 per seal down to $6, I found for our '55 Sovereign a SKF-18872 seal seems to be the ticket. It is 3 x 1.875 and has a double lip.
S.E. Michigan
Need Bearing Seal Part Number for '66 Safari rhmorgan Axles 11 11-26-2008 12:39 PM
Wheel bearing & seal specs for 2005 Classic 30 Wingeezer 2005 - Classic (all lengths) 0 11-03-2008 06:01 PM
Need Bearing Seal Part Number for 2000 30' Excella Cracker Wheels 3 06-09-2008 07:19 PM
Brake shoes and bearing seal source needed. sfixx All Argosy Trailers 2 11-23-2004 05:25 PM
