Old 09-28-2004, 11:34 AM   #15
Just bought a prodigy controller. Thanks
Ivo
Originally Posted by garry
You may already know this BUT just in case the trailer brakes require an electric brake controller located in the cab of your tow vehicle.
If the dealer or shop you have the bearings work done is not an AS dealer then as others have said make sure you show them where to place the jack. They will tell you they do this all the time and know how to jack up a TT and then jack it up by the axles.
Garry
Ivo & Lisa Waerlop
1976 25' Land Yacht
Parshall, Colorado
...The World is your Mollusk....
drivo is offline   Reply With Quote
Old 09-28-2004, 12:01 PM   #16
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
Thanks for the invite. WE won't be able to makke either in October, but would be interested in others. Can you send more info?
Ivo
Check out the DenCO Unit's website under 'Upcoming Events'...it's kept up to date with all the scheduled activities ~
Look forward to meeting you
Shari
Wheel Bearing Numbers Pick Axles 5 09-27-2004 06:46 PM
'66 Tradewind wheel bearing size? dreamqueen 1959-69 Tradewind 1 02-18-2004 07:13 PM
Wheel bearing part #s Ultradog Axles 6 05-17-2003 02:29 AM
Wheel Bearing?? - - or - - Brakes?? overlander64 Axles 8 11-24-2002 01:13 AM
Wheel Bearing Temperature Road Ruler Axles 23 10-16-2002 09:54 AM
