Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Axles
Old 05-16-2003, 06:32 PM   #1
Huh?
Ultradog's Avatar
Profile:  1975 27' Overlander
Minneapolis , Minnesota
Images: 8
Wheel bearing part #s
Hello all,
This is my first post here.
Well, I tried to ask this question last night but must have done something wrong because I can't find it anywhere.
Anyway,
I'm going to pick up my "new" Airstream tomorrow.
It's a 1967 Airstream Tradewind 24' Land Yacht.
I'll be pulling it home from about 200 miles away.
The seller says it's all ready to go but I would feel much better if I could bring an extra wheel bearing and race/s along.
Does anyone happen to know what the part #s would be for these items?
Would a place like Napa or Northern carry them or will I have to go to a more specialized bearing house or a dealer?
I've been looking around this site for a couple of days now and am really impressed with the vast amount of knowledge here.
What a great site!
Anyway, thanks to any and all.
This is just my first question. I'm sure it wont be the last.
Jerry Lemire
Mpls MN
Ultradog is offline   Reply With Quote
Old 05-16-2003, 07:35 PM   #2
59toaster's Avatar
Profile:  1959 22' Caravanner
Atlanta , Georgia
Images: 22
Congradualtions and welcome to the forum!
Well most bearings are pretty easily obtainable at most parts stores. On the edge of the bearing race is usualy a part number that most parts stores, like Napa and Autozone, can cross refference. I personnaly like the Timkin brand sold at Autozone.
I know that's not helping you at this point but maybe somebody has a set laying around and can get you that part number. There will be both a part number for the outer race that you would press into the hub as well as one on the inner race that is captive to the rollers.
Hopefully Andy from Inland RV will see the post and might be able to provide the numers. He's a wealth of information.
http://www.inlandrv.com/ is Inlands web site.
Look forward to seeing some pictures.
1959 22' Caravanner
1988 R20 454 Suburban.
Atlanta, GA
59toaster is offline   Reply With Quote
Old 05-16-2003, 08:06 PM   #3
Retired Moderator
john hd's Avatar
Profile:  1992 29' Excella
madison , Wisconsin
Images: 40
viroqua?
jerry
could your trailer be the one i saw on e bay?
200 miles is not that far, if the p.o. sez it is ready to go it might be.
after being involved in dragging two vintage trailers home with a friend of mine, all i can say is give it a shot.
if you get going, stop after 20 miles or so stop and feel the bearings (hub) with your hand. it should be cool, or at least mildly warm. not so hot that you cannot keep your hand on it.
most likely you will need to rewire the trailer plug to match your tow vehicle. take a spare plug that matches what you have.
worst case you will need to do a roadside repair, as toaster pointed out, bearings are common and should be available at napa. oil seals as well.
just make sure the brakes work, for everyones safety.
go by your gut, if it looks like a dangerous set up don't tow it. then come back later with the stuff you need to do the job right. it is only 200 miles after all. worst case you'll be out, is an afternoon.
good luck, welcome to the forum, and let us all know how it goes!
john
Old 05-16-2003, 08:38 PM   #4
Huh?
Ultradog's Avatar
Images: 8
Re: viroqua?
[QUOTE]Originally posted by john hd
[B]jerry
Yes John it's the one from Viroqua.
I'll be going down to pick it up early tomorrow.
I know almost nothing about these Airstreams
so I didn't know if things like brakes wheel bearings and the like are standard items or if they are special to AS.
I saved my self a bunch of time and grief once on the AlCan because I just happened to have a spare front wheel bearing for my truck. I figured a spare for this trailer would be easy to stash in a corner somewhere.
I have a 7 pin outlet on my PU but it is the new style with the rectangular pins. Shall I presume that this AS will have the old style plug with the round pins?
Thanks for the heads up on that.
I spoke to the PO on the phone a couple of times and he seems like a pretty straight shooter.
So I might like you say, just hook up and go and check the tires and wheel bearings regularly.
The old "wing and a prayer" theory.
The prayer I can do.
It's them wings that are hard to find...
Old 05-16-2003, 09:45 PM   #5
Moderator Emeritus
Pick's Avatar
Profile:  1972 31' Sovereign
High Springs , Florida
Images: 36
Here are the cup and cone numbers
One pair:
25580
25520
Other pair:
LM67010
LM67048
Sorry, don't remember which is inner or outer. Don't remember which is cup or cone.
CP 9 miles off Exit 399, I75.
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
Old 05-17-2003, 02:04 AM   #6
Retired Moderator
john hd's Avatar
madison , Wisconsin
Images: 40
sparta
jerry,
i knew someone would come through with the numbers, way to go pick.
if you need to get parts, sparta wi is the closest thing to civilization.
if the trailer has its original plug, the reverse lights and charge line might need to be swapped.
i may very well plug right into your truck with a little rewire.
john
Old 05-17-2003, 02:29 AM   #7
53flyingcloud's Avatar
Profile:  1984 29' Sovereign
Savannah , Missouri
Send a message via ICQ to 53flyingcloud Send a message via Yahoo to 53flyingcloud
Thumbs up Good Show~
pick, since you did the hard part..Here's the rest..
A.
1)25520= inner cup
2)25580=inner cone
3)25821=outer cup
4)25877=outer cone
B.
1)LM67010= inner cup
2)LM67048= inner cone
3)LM11910=outer cup
4)LM11949=outer cone
Here's but a few websites for references.
Walt's Tractor
Fulton Performances
I saw prices all over the place..
Some quoted as low as 6.68$ per bearings.
Hope this helps.
Hey guys, in doing this research..I used Google.com
Well, in the beginning..I was on the first page that pop'd up when I entered the numbers and, NOW..It had updated itself to include this thread from Pick~!!! linked to Airstreamforums.com..
WAY TOO KEWL...
Just thought you'd like to know...lol
As seen on Google.com
Pick's originial thread
ciao
WBCCI 5292 AIR 807
NEU #64
New England Unit
53flyingcloud is offline   Reply With Quote
Wheel Bearing Numbers Pick Axles 5 09-27-2004 06:46 PM
'66 Tradewind wheel bearing size? dreamqueen 1959-69 Tradewind 1 02-18-2004 07:13 PM
Wheel Bearing?? - - or - - Brakes?? overlander64 Axles 8 11-24-2002 01:13 AM
Wheel Bearing Temperature Road Ruler Axles 23 10-16-2002 09:54 AM
Wheel Bearing seals!!! niftypkg Axles 1 07-30-2002 04:35 PM
