Old 02-28-2003, 06:09 PM   #1
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
High Springs , Florida
Images: 36
Wheel Bearing Numbers
For Smiley and other interested parties:
Large inside bearing: 25580
Small outside bearing: LM67048
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 03-01-2003, 06:19 AM   #2
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
Question grease seal
pick
are your seals chicago rawhide (CR) 22550 ?
john
Old 03-01-2003, 07:54 AM   #3
53flyingcloud's Avatar
1984 29' Sovereign
Savannah , Missouri
Lightbulb Combine these two?
Pick
Why couldn't we combine these two together?
Replace Wheel Bearings?
Make it easier to follow the train of info..
ciao
BTW, thanks for the great research. I'd like to see more info and, even demo on the replacements of this often overlooked item!
WBCCI 5292 AIR 807
NEU #64
New England Unit
53flyingcloud is offline   Reply With Quote
Old 03-01-2003, 10:12 AM   #4
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
Images: 36
John HD, my bearing seals came from Henschen when I picked up the axles. Didn't see any numbers on them, but I'll check again. They had the blue sealant on the outside edges, with the spring loaded seal.
53FlyingCloud, I thought this would get more attention posting this way as another gentleman was interested in the numbers also. There is a great article on brake service and wheel bearing repacking in this months Trailer Life magazine.
ARS WA8ZYT
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 03-01-2003, 10:19 AM   #5
1984 29' Sovereign
Savannah , Missouri
Thumbs up Understand
Pick,
Gotcha,..btw, I saw that briefly and, like so many things...Now I can't find my magazine..lol,
Thanks...btw, my bearings have been keeped greased, just like to be able to get into it myself.
What is the recommanded torque value for the wheel lugs?
I had this once and, now I can't seem to put my hands on it.
ciao
WBCCI 5292 AIR 807
NEU #64
New England Unit
Old 09-27-2004, 05:46 PM   #6
Tarheel's Avatar
2001 34' Limited S/O
Moyock , North Carolina
Images: 21
80-90 ft/lbs. It doesn't take very long to repack the wheel bearings and is a fairly simple diy job. I like to do it just so I can look at my brakes and see just what is going on inside my wheels. I have never had a wheel bearing problem, I look at them each winter just before pulling to Florida from North Carolina. I have found broken springs on the brakes. I just feel better doing the inspection myself. It's also a good time to look at tire wear and sidewall condition. I like to replace my tires on a 5 year cycle.
Keep the shiny side up.
WBCCI # 348
Past Region 3 President
Rick Bell in "Silverbell"
Tarheel is offline   Reply With Quote
'66 Tradewind wheel bearing size? dreamqueen 1959-69 Tradewind 1 02-18-2004 06:13 PM
Bearing Numbers Myrjer Axles 6 07-26-2003 07:33 PM
Wheel bearing part #s Ultradog Axles 6 05-17-2003 01:29 AM
Wheel Bearing?? - - or - - Brakes?? overlander64 Axles 8 11-24-2002 12:13 AM
Wheel Bearing Temperature Road Ruler Axles 23 10-16-2002 08:54 AM
