Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Axles
Old 02-28-2003, 06:09 PM   #1
Pick
Pick's Avatar
Profile:  1972 31' Sovereign
High Springs , Florida
Images: 36
Wheel Bearing Numbers
For Smiley and other interested parties:
Large inside bearing: 25580
Small outside bearing: LM67048
CP 9 miles off Exit 399, I75.
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
Old 03-01-2003, 06:19 AM   #2
john hd
john hd's Avatar
Profile:  1992 29' Excella
madison , Wisconsin
Images: 40
Question grease seal
pick
are your seals chicago rawhide (CR) 22550 ?
john
Old 03-01-2003, 07:54 AM   #3
53flyingcloud
53flyingcloud's Avatar
Profile:  Amherst , New Hampshire
Lightbulb Combine these two?
Pick
Why couldn't we combine these two together?
Replace Wheel Bearings?
Make it easier to follow the train of info..
ciao
BTW, thanks for the great research. I'd like to see more info and, even demo on the replacements of this often overlooked item!
53flyingcloud is offline   Reply With Quote
Old 03-01-2003, 10:12 AM   #4
Pick
Pick's Avatar
Images: 36
John HD, my bearing seals came from Henschen when I picked up the axles. Didn't see any numbers on them, but I'll check again. They had the blue sealant on the outside edges, with the spring loaded seal.
53FlyingCloud, I thought this would get more attention posting this way as another gentleman was interested in the numbers also. There is a great article on brake service and wheel bearing repacking in this months Trailer Life magazine.
Lots of Hot Sauce!
Air # 283
Old 03-01-2003, 10:19 AM   #5
53flyingcloud
Thumbs up Understand
Pick,
Gotcha,..btw, I saw that briefly and, like so many things...Now I can't find my magazine..lol,
Thanks...btw, my bearings have been keeped greased, just like to be able to get into it myself.
What is the recommanded torque value for the wheel lugs?
I had this once and, now I can't seem to put my hands on it.
ciao
Old 09-27-2004, 05:46 PM   #6
Tarheel
Tarheel's Avatar
Profile:  2001 34' Limited S/O
Moyock , North Carolina
Images: 21
80-90 ft/lbs. It doesn't take very long to repack the wheel bearings and is a fairly simple diy job. I like to do it just so I can look at my brakes and see just what is going on inside my wheels. I have never had a wheel bearing problem, I look at them each winter just before pulling to Florida from North Carolina. I have found broken springs on the brakes. I just feel better doing the inspection myself. It's also a good time to look at tire wear and sidewall condition. I like to replace my tires on a 5 year cycle.
Keep the shiny side up.
WBCCI # 3485
Region 3 1stVP
Past President Tidewater Unit 111
visit tidewater Virginia's web page @
www.tidewaterwbcci.com
Rick Bell in "Silverbell"
Tarheel is offline   Reply With Quote
'66 Tradewind wheel bearing size? dreamqueen 1959-69 Tradewind 1 02-18-2004 06:13 PM
Bearing Numbers Myrjer Axles 6 07-26-2003 07:33 PM
Wheel bearing part #s Ultradog Axles 6 05-17-2003 01:29 AM
Wheel Bearing?? - - or - - Brakes?? overlander64 Axles 8 11-24-2002 12:13 AM
Wheel Bearing Temperature Road Ruler Axles 23 10-16-2002 08:54 AM
