Old 06-20-2006, 12:30 PM   #15
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Originally Posted by Didgiman
...but I do not know what type or where to get new wheel bearing gaskets for my 68 globetrotter. If anyone has an idea please chime in. Sometime they are refered to as axel gaskets. Sincerely, Didgiman
Axle gaskets would be for an axle that has a shaft running through to the hub. The gasket would seal the end of the axle to the bearing race area. The other area would be an application of the braking backing plate having a gasket in the area where it meets the spindle.
Airstream and other travel trailers do not have drive axles and there is not a need to dissassemble the brake backing plate when repacking the wheel bearings. Hope this helps.
You will only need the grease seals that are correct for your wheel bearings. One for each wheel.
>>>>>>>>>>>>>>>Action
Wheel Bearing Adjustment Dwight Axles 9 05-15-2008 05:50 AM
Synthetic Wheel Bearing Grease Pick Axles 4 11-24-2002 08:18 PM
Wheel Bearing?? - - or - - Brakes?? overlander64 Axles 8 11-24-2002 12:13 AM
Wheel Bearing Temperature Road Ruler Axles 23 10-16-2002 08:54 AM
Wheel Bearing seals!!! niftypkg Axles 1 07-30-2002 03:35 PM
