Old 03-10-2010, 07:17 PM   #1
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
What's wrong with this picture?
A 1955 Flying Cloud came in to the shop today for a safety inspection and some plumbing repairs. I got a surprise when I crawled underneath. Can you see what's wrong in this picture? Besides the obvious fact the photo is rotated...
Old 03-10-2010, 07:24 PM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
A 55 FC should have originally had a spring and axle setup and you can see the shackles for the springs. Someone replaced it with a torsion axle somewhere down the road, but how is the axle attached to the frame?
Richard
Old 03-10-2010, 07:25 PM   #3
1962 28' Ambassador
1962 30' Sovereign
Webster Groves , Missouri
NO SPRINGS! A torque axil on a 55! (Needs replacement)
Xbob2 is offline   Reply With Quote
Old 03-10-2010, 07:27 PM   #4
Central , Mississippi
Is that a "leading" arm torsion suspension?
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 03-10-2010, 07:50 PM   #5
aircooled4's Avatar
1971 31' Sovereign
1967 22' Safari
1958 22' World Traveler
Pardeeville , Wisconsin
hmmm...yep, torsion axle...kinda scary....
Jay (KB8VMO)
WBCCI #10917
AIR #32349
TAC #WI-2
aircooled4 is offline   Reply With Quote
Old 03-10-2010, 08:29 PM   #6
Maniacal Engineer
barts's Avatar
Menlo Park , California
From a mech. engineering standpoint, the reversed axle can cause problems during braking.... but if the unit has no trailer brakes, this will have little practical effect. The real issue for me is that the axle brackets appear to be welded to the edge of a mounting plate; this places a heavy bending load on that plate during cornering and is not safe if that plate isn't heavy and properly welded to the frame.
If the torsion axle is desirable, the safest way to proceed IMO is to connect the spring hangers w/ a piece of 2" square tube w/ a proper axle mounting plate welded on. If this trailer was fitted w/ a drop axle originally, this may make for an excessive ride height unless the axle is mounted above the 2" tube....
- Bart
Bart Smaalders
Menlo Park, CA
http://tinpickle.blogspot.com
http://smaalders.net/barts
barts is offline   Reply With Quote
Old 03-10-2010, 09:05 PM   #7
Well Preserved
1993 21' Sovereign
Yes, the torsion axle was installed reversed, and welded (badly) to a single piece of steel which was also welded (badly) to the frame. It is a used axle off a 1961-1962 Airstream, and the 12" (original 1962), in addition to being also installed reversed, are hooked up. The steel plate that holds the torsion axle in place flexes when the trailer moves, either by towing, or even by walking around inside. The original shock brackets for the 1961-era axle have been partially torched off as well, so not even shocks on this study of rationalization.
The owner of the trailer is going to make a decision on whether to replace the hacked-up axle with a new torsion axle, or replace it with a leaf spring axle. I'm leaning toward cutting off the "stuff" that's there, and replacing it with a leaf spring axle. The trailer shell isn't bad, it being a California Dutchman Panel model. the interior, well... what's there is in good shape, though more of it isn't "period" than I'd like, if 'twere mine. I'll take a camera to work tomorrow, so we don't have to stand our monitors on their sides to view the photos.
Old 03-10-2010, 09:18 PM   #8
Whooo Hoooo! So I win an ArtSteam T Shirt and pick next months subject!
Oops...wrong thread....
Anyway, I have seen what a leading axle does under braking/ acceleration on some 'non-american' military transport vehicles. Its ugly.
It would be cool to re-install a proper spring axle.
Old 03-10-2010, 09:27 PM   #9
Well Preserved
1993 21' Sovereign
Yes, I'm trying to lead the customer in that direction, though we can put in whichever one he wants. We have the technology, and we can bring it in under $6 million...
Old 03-10-2010, 10:48 PM   #10
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Could it be for sale
Co-incidence?
Airstream Flying Cloud
Look under here and tell me what's wrong connorsa Ribs, Skins & Rivets 6 07-13-2009 09:51 AM
What's wrong with this picture? Sheridan Tow Vehicles 12 04-09-2009 03:27 PM
This is just wrong... ericwarren Our Community 13 09-16-2008 04:07 PM
What's wrong with this picture? Pecos Pete Our Community 5 02-03-2007 08:52 PM
Hmmmmm... what's wrong with this picture Tin Diesel Towing, Tow Vehicles & Hitches 6 05-21-2006 06:11 PM
