Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Axles
Old 01-20-2004, 12:16 PM   #1
jkenny's Avatar
Profile:  1969 27' Overlander
Lake Grove , New York
Question What is behind my tire?
Does anyone know what the device is mounted behind each tire on my 1969 Overlander. I dont currently have a picture of it but it looks like a hollow cylinder with a stiff metal wire through the center. I think it may be connected to the electric brakes somehow (it is too damn cold in NY to go poking around on the ground right now). Maybe it is a "sensor" so in the case of a flat tire the brake does not get engaged on that tire.
jkenny is offline   Reply With Quote
Old 01-20-2004, 06:24 PM   #2
jkenny's Avatar
Here is a picture of the part in question
Well, Since there was no reply I braved the cold, stuck my camera behind the tire and snapped away. I actually got a good shot of the part I am wondering about.
I plan to rewire the brakes this spring but it is just bothering me that I dont know what the device is.
Has anyone seen anything like this or do you have something similar on your trailer? Without getting a close look at the exact wiring of this device I can only guess it either applies or prevents the application of the brakes due to a flat or loss of wheel.
Old 01-20-2004, 06:31 PM   #3
Well-Preserved
overlander63's Avatar
Profile:  1974 31' Sovereign
Somewhere , Over the Rainbow
Looks like a spring of some kind. I don't know why one would be there, at that angle, unless the other end had rotted off, and was hanging down. I see similar things on cars, they hold the parking brake cable away from the tire so it won't rub. Maybe it was something similar for the wires to the brakes? Ask Andy from Inland, he knows everything about these (or at least I haven't stumped him yet!)
(No Longer at Inland RV)
overlander63 is online now   Reply With Quote
Old 01-20-2004, 07:22 PM   #4
87MH's Avatar
Profile:  1978 31' Sovereign
Katy , West Planet Houston, Texas
Images: 234
How about a WAG?
It COULD be a crude flat tire sensor.
Tire goes flat, rod drags on ground, rod makes contact with pipe, sends signal to driver.
Just a guess.
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign Photos:'78 Sovereign Rebuild
Motorhome '87 Classic Motorhome Saga
Old 01-20-2004, 09:06 PM   #5
garry's Avatar
Profile:  1969 31' Sovereign
Broken Arrow , Oklahoma
flat warning
looks as if it has two wires so flat tire sensor sounds correct
Old 01-20-2004, 10:25 PM   #6
Profile:  , Minnesota
Images: 59
Airstream Registry
St' Elmo's Fire!
Maybe it's a static eliminator?
Old 01-21-2004, 01:21 PM   #7
Profile:
Images: 55
I too think it could be a static eliminator. I remember reading something regarding this sometime in the past on the forum.
Weird.
Tripp
Tripp is offline   Reply With Quote
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
