05-04-2017, 11:01 AM
kerrville
What is attached to this axle?
Feel free to opine. There is one on each side.
Ground device? Helper springs attached upside down to act as stationary stabilizers?
What?
hankpac@yahoo.com
05-04-2017, 11:04 AM
2007 30' Classic
Oswego
It was designed to be a skid bar in the event of a flat tire or a wheel coming off. I think most folks remove them.
-Rich-
05-04-2017, 11:33 AM
Moderator dude
1966 26' Overlander
Phoenix
And used only on AS trailers about 50 to 60 years ago. It does have some historical significance.
We gripe about tires now days. What do you think the tire quality was back then if such a devise was actually installed?
>>>>>>>>>Action
05-04-2017, 11:38 AM
1966 22' Safari
Fredericksburg
Hankpac, what is your model and year? Thanks
05-04-2017, 02:18 PM
kerrville
skid bars?
This is a 64 or 65. Not mine, a friend.
05-04-2017, 02:52 PM
2006 23' Safari SE
Biloxi
, Mississippi
Were these aftermarket installed or by the factory? First time I have seen one.
MICHAEL
05-04-2017, 03:04 PM
1973 21' Globetrotter
Houston
Yep, these were called something like a "tire saver," the idea being that if your tire went flat, the device would make contact with the ground rather than allowing you to ride on the rim until it cuts the tire and uses it to destroy the wheel well. They were available as a factory installed option.
05-04-2017, 03:47 PM
An added benefit was provided by the spectacular rooster tail of sparks that warned following drivers to slow down until you were safely pulled over.
05-04-2017, 05:38 PM
1975 31' Sovereign
Palomar Mountain
Fantastic idea - see no downside.
05-04-2017, 06:01 PM
Moderator dude
1966 26' Overlander
Phoenix
Could catch debris from the road.
Another part to fail.
If you keep your tires current it is not needed
Could catch debris and have that debris cut a tire.
Elicits questions from observers.
Could catch debris
>>>>>>>>>>>Action
05-05-2017, 12:00 PM
2015 25' Flying Cloud
2016 30' Flying Cloud
Blenheim Ontario
Except from Action
05-05-2017, 12:06 PM
Moderator dude
1966 26' Overlander
Phoenix
LOL
>>>>>>>>>>>>>Action
05-05-2017, 04:24 PM
1968 22' Safari
Shillington
, Pennsylvania
What is this?
I have this device on my 1968 single axel Safari. It is a skid to take the weight of the trailer in the event of a flat tire on the road. Because we have single axel trailers, a flat tire could end up in a role over without the skid to keep that side of the trailer up. I have not had the need to use it, thank goodness, but glad they are there.
05-05-2017, 05:03 PM
Tampa
I never saw one either until I came across this:
05-05-2017, 06:07 PM
Blenheim Ontario
I think that it's a very good idea, that should be brought back.
The potential for saving the wheel and coachwork is pretty obvious.
05-05-2017, 06:59 PM
1967 22' Safari
Monona
, Wisconsin
On our 67 Safari
They were on our 67, 22-ft., Safari. Changed out the axle and reinstalled. I sure think they are a great idea.
Greg Anderson
Monona, WI
05-05-2017, 09:24 PM
Tampa
Just curious.
In the 60's I don't recall any torsion axles, I thought they were all leaf spring.
And yet all these photos show a torsion style axle.
05-05-2017, 10:44 PM
Moderator dude
1966 26' Overlander
Phoenix
Airstream switched from leaf to torsion spring in about 1961/
>>>>>>>>>Action
