Old 05-04-2017, 12:01 PM   #1
kerrville , Texas
What is attached to this axle?
Name:	65 Airstream.jpg
Feel free to opine. There is one on each side.
Ground device? Helper springs attached upside down to act as stationary stabilizers?
What?
hankpac@yahoo.com
Hankpac is offline   Reply With Quote
Old 05-04-2017, 12:04 PM   #2
dznf0g's Avatar
Oswego , Illinois
It was designed to be a skid bar in the event of a flat tire or a wheel coming off. I think most folks remove them.
-Rich-
Old 05-04-2017, 12:33 PM   #3
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
And used only on AS trailers about 50 to 60 years ago. It does have some historical significance.
We gripe about tires now days. What do you think the tire quality was back then if such a devise was actually installed?
>>>>>>>>>Action
Old 05-04-2017, 12:38 PM   #4
1966 22' Safari
Fredericksburg , Texas
Hankpac, what is your model and year? Thanks
Bubba L is online now   Reply With Quote
Old 05-04-2017, 03:18 PM   #5
kerrville , Texas
skid bars?
This is a 64 or 65. Not mine, a friend.
Old 05-04-2017, 03:52 PM   #6
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Were these aftermarket installed or by the factory? First time I have seen one.
MICHAEL
Old 05-04-2017, 04:04 PM   #7
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
Yep, these were called something like a "tire saver," the idea being that if your tire went flat, the device would make contact with the ground rather than allowing you to ride on the rim until it cuts the tire and uses it to destroy the wheel well. They were available as a factory installed option.
Old 05-04-2017, 04:47 PM   #8
Images: 59
An added benefit was provided by the spectacular rooster tail of sparks that warned following drivers to slow down until you were safely pulled over.
Old 05-04-2017, 06:38 PM   #9
Silver Hawk's Avatar
1975 31' Sovereign
Palomar Mountain , California
Fantastic idea - see no downside.
Silver Hawk is offline   Reply With Quote
Old 05-04-2017, 07:01 PM   #10
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Could catch debris from the road.
Another part to fail.
If you keep your tires current it is not needed
Could catch debris and have that debris cut a tire.
Elicits questions from observers.
Could catch debris
>>>>>>>>>>>Action
Old 05-05-2017, 01:00 PM   #11
2015 25' Flying Cloud
2016 30' Flying Cloud
Blenheim Ontario , Ontario
Except from Action
MelGoddard is offline   Reply With Quote
Old 05-05-2017, 01:06 PM   #12
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
LOL
>>>>>>>>>>>>>Action
Old 05-05-2017, 05:24 PM   #13
1968 22' Safari
Shillington , Pennsylvania
What is this?
I have this device on my 1968 single axel Safari. It is a skid to take the weight of the trailer in the event of a flat tire on the road. Because we have single axel trailers, a flat tire could end up in a role over without the skid to keep that side of the trailer up. I have not had the need to use it, thank goodness, but glad they are there.
jimstream is offline   Reply With Quote
Old 05-05-2017, 06:03 PM   #14
Mollysdad's Avatar
I never saw one either until I came across this:
Old 05-05-2017, 07:07 PM   #15
I think that it's a very good idea, that should be brought back.
The potential for saving the wheel and coachwork is pretty obvious.
Old 05-05-2017, 07:59 PM   #16
gdanderson's Avatar
1967 22' Safari
Monona , Wisconsin
On our 67 Safari
They were on our 67, 22-ft., Safari. Changed out the axle and reinstalled. I sure think they are a great idea.
Greg Anderson
Monona, WI
gdanderson is offline   Reply With Quote
Old 05-05-2017, 10:24 PM   #17
Mollysdad's Avatar
Just curious.
In the 60's I don't recall any torsion axles, I thought they were all leaf spring.
And yet all these photos show a torsion style axle.
Old 05-05-2017, 11:44 PM   #18
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Airstream switched from leaf to torsion spring in about 1961/
>>>>>>>>>Action
An axle is an axle is an axle? Globie64 Axles 45 01-01-2012 02:25 PM
'89 Excella 25 mystery switch? Pix attached also... BillTex 1987 - 1989 Excella 12 05-22-2011 02:05 PM
'62 Bambi - window operator not attached kamo Windows & Screens 3 08-16-2006 06:34 PM
Outdoor screened room attached to awning??? a-wanabbee Awnings 1 04-26-2006 01:01 AM
How cabinets are attached to the skin 58BUBBLE Cabinets, Counter Tops & Furnishings 3 03-05-2005 11:55 PM
