Old 06-14-2008, 03:40 AM   #1
HansenClan's Avatar
1965 26' Overlander
Encinitas , California
Images: 22
What if?? (on my trailer)
Originally Posted by Inland RV Center, In View Post
Now that you know your Airstream has good axles, you will now travel with much more piece of mind, knowing that you won't beat the trailer to pieces.
May all your Airstreaming days, and nights too, be great ones.
What if you can see 3 or so inches of tire but the angle of the torsion arms are zero (or horizontal to the ground) when the trailer is empty?
65 26' Overlander
HansenClan is offline   Reply With Quote
Old 06-14-2008, 06:34 AM   #2
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
65 26' Overlander
2 other suggestions to assess your axles:
1. Jack up the trailer. As you jack up the trailer the tires should stay in contact with the ground for at least a couple of inches.
2. Have someone tow you down a bumpy road while you ride in the coach and see if the ride is reasonably smooth. Look for any movement in the interior of the coach that is not uniform and out of sync that suggests axle shock is being directly transferred to the coach and not buffered by the axles and shocks. The trailer ride will be different from the TV because it's a different vehicle. My pick up is a 3/4 ton and rides a lot harder than my Tradewind. I tow my AS based on how the trailer rides, not so much the TV.
Old 06-15-2008, 07:05 PM   #3
HansenClan's Avatar
1965 26' Overlander
Images: 22
Thanks for your help... :-)
