Old 10-08-2007, 11:14 AM   #1
boondockdad's Avatar
2008 30' Classic S/O
Dearborn , Michigan
Images: 21
what axles 2008 Classic 30 s/o?
dexter 3.5k, 8k, 10k....
boondockdad is offline   Reply With Quote
Old 10-08-2007, 11:53 AM   #2
Parts data says 5000 pounds with disc brakes.
Old 10-08-2007, 07:15 PM   #3
Dearborn , Michigan
Images: 21
thanks andy
hoping to find service literature on brake... need to bleed system... found the bleeder valve on the outside of the calipers... maybe i can get to it without taking off the rims...
Old 10-08-2007, 07:27 PM   #4
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
thanks andy
Why bleed a brand new brake system?
Uwe
www.area63productions.com
Old 10-09-2007, 04:47 AM   #5
Dearborn , Michigan
Images: 21
the actibrake hydraulic system recommends you bleed the system after the first 100 miles... the dealer i bought from didn't do it at prep... now i'm getting a 2-3 sec delay in braking response...
after talking with actibrake about the symptoms... he was almost 99% sure it was air in the lines...
we'll see...
i don't want to drive it anywhere with the brakes the way they are...
Old 10-09-2007, 06:52 AM   #6
_
hi final cut joe...
dexter has a great website full of details on their axles, brakes and bearings...
Dexter Axle - Trailer Axles and Running Gear Components - RESOURCE LIBRARY
the actibrake site isn't as detailed but the installation manual (online) has good info...
Active Technology-New
i have kodiak brake mechanicals, but i think yours are dexter....
cheers
2air'
Old 10-09-2007, 09:09 AM   #7
Dearborn , Michigan
Images: 21
Originally Posted by 2airishuman
hi final cut joe...
cheers
2air'
thanks 2air,
already combed the dexter resource library...
a lot of stuff, but nothing on bleeding or diagrams...
after talking with tech, seems simple enough... pretty much the same procedure as my '82 CJ ...
i just dont want to have to take the wheels off to get to the bleeder valve... if i can get an open end wrench in there, without knicking up the rims....
maybe i'll put some wide painters tape around the spokes in that area... is that being a little too anal?
Old 10-09-2007, 10:04 AM   #8
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
Is your controller gain and or boost set properly? Did you make sure the controller and actibrake are synced? Mine were not bleed until they had to remove the belly pan.
Michelle TAC MT-0
Sarah, Snowball
Old 10-09-2007, 11:13 AM   #9
Dearborn , Michigan
Images: 21
i thought syncing happened everytime you plugged in the trailer cable?
the gain works great... can lock 'em up at around 8... dialed it down to 7.2... the boost is pretty much negated since there's such a big delay in brake response...
Old 10-09-2007, 08:25 PM   #10
Keymar , Maryland
No, For an actibrake actuator you need to hook it up to the truck turn the gain all the way up in my case 10 (Ford Tow command) and actuate the manual lever fully several times. Any time you disconect the batteries, let them get low or switch tow vehicles you need to do this. This lets the computer in the acutator know what maximum signal to expect and proportionally apply brakes when you set the gain and step on the brake pedal.
Michelle TAC MT-0
Sarah, Snowball
Old 10-10-2007, 04:32 AM   #11
Dearborn , Michigan
Images: 21
i completely missed that in the a/s literature.... (not that there wasn't a TON of it)
too bad the dealer didn't know this...
thanks!
Axles Axles Axles GeocamperAS Axles 33 11-20-2015 12:01 PM
2008 31' Classic / 2008 Silverado 2500 4x4 duramax ddarr2 Member Introductions 19 03-09-2010 12:14 PM
Towing 2008 19' Bambi with 2008 Toyota Highlander JDBfreeheel Tow Vehicles 1 03-08-2008 09:27 PM
2008 Tundra & 2008 Land Cruiser TV advice Ray Eklund Tow Vehicles 2 02-21-2008 07:49 PM
