Old 03-17-2009, 09:00 AM   #1
tphan's Avatar
1972 27' Overlander
Longmont , Colorado
What about these axles? - (pics)
So these look bad too, right? 1 pic is of typical arm angle under standard load, the other is with wheel/tire hanging under no load, and what bothers me about that one is the minimal downward sag of the axle arm, nowhere near 22 degrees. It would appear to be somewhat frozen up, meaning replacement time. But- there is at least an inch of tire showing above the wheels- so it's a little ambiguous info. What do you think? thanks, tim
ID:	77060   Click image for larger version
tphan is offline   Reply With Quote
Old 03-17-2009, 10:26 AM   #2
There are 2 axle tests.
One is the position of the torsion arm when loaded. In your case, if the trailer is loaded, then not too bad.
Two, is when the side is jacked up, observing the amount of tire drop. The tire should drop about 3 inches. If not, then the rubber rods have solidified, which will cause avery rough ride for the trailer.
In that case, replacements are in order.
Old 03-17-2009, 02:41 PM   #3
Tom, the Uber Disney Fan
Minnie's Mate's Avatar
2006 30' Safari
Orlando , Florida
From one metro-Atlantan to another, welcome to the forums. And sorry about the axles, but she's a beauty!
Family of Disney Fanatics
WBCCI# 4821
A few new Pics of my two cameront120 The Pet Forum 12 05-12-2008 06:48 PM
Dexter Axles here with pics!! TN-TUNDRA Axles 27 11-23-2007 09:32 PM
some '81 pics Pacerized 1981 Excella II 21 05-20-2007 09:51 PM
My new Squaregosy pics wanderer1 Off Topic Forum 3 04-22-2007 08:42 AM
Pics of my first AS jamesardis Member Introductions 24 01-22-2006 04:58 AM
