Old 10-20-2008, 08:32 PM   #1
Easton , Connecticut
weight distribution question
I wasn't sure where to put this, but I appreciate the help.
In my planning of converting an Airstream to a mobile kitchen, I'm curious if I should consider buying a two axle model to help distribute the weight more?
ctdadof3g is offline   Reply With Quote
Old 10-20-2008, 08:39 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Yes, the smallest 2 axle Airstream I remember was 21'. I would try to keep trailer length below 26', it will be easier to park.
Old 10-20-2008, 08:47 PM   #3
I agree. I'm not looking forward to backing it down my driveway when I do get one.
Old 10-20-2008, 08:53 PM   #4
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
I think you need to look at the size that you need to build your kitchen and the total weight of your project, then find a trailer that will fit both of these requirements.
Richard
Old 10-22-2008, 08:56 AM   #5
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Total weight IS your only consideration at this point. The smaller a 2 axle trailer you find the lighter weigth rating it will have.
If you are gutting a trailer typlically the weight you put in should not exceed the weight you reinstall. These trailers (and every other brand I know) have an axle capacity to accomodate everything built into them and a small percent greater. So if the trailer has a GVWR of 5000 #'s the axle(s) will be rated just over that and the empty weight of a complete trailer is going to be like 85 to 90 percent of that.
Drag in a heavy commercial cooking gear and you will have issues with a standard set up.
All of the above assumes the axles are in good shape. If you are doing this to a trailer that is older than 20 years, seriously look at axle(s) replacement with a higher weight carrying capacity.
And this is assuming you want to move the trailer to different locations. If it is a stationary project then all of the above becomes just talk. Find acceptable foundation for this application.
>>>>>>>>>>>>Action
tv and tt weight distribution SKEETER Tow Vehicles 7 06-18-2008 09:46 PM
Refined TV weight numbers = required weight distribution? flyfishfred Hitches, Couplers & Balls 4 01-12-2008 08:13 PM
Weight Distribution Question Randy Johnson Hitches, Couplers & Balls 63 07-21-2003 10:57 AM
Weight Distribution newae On The Road... 9 07-18-2003 10:08 PM
weight distribution Craig Hitches, Couplers & Balls 2 04-14-2003 06:57 PM
