Old 10-15-2016, 08:49 AM   #15
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Originally Posted by 80Caravelle View Post
Thanks for the advice - I've decided to swap out the axel and, if it's not too much more, weld on a bracket for shock absorbers. Hopefully that'll keep my going for a while.
You can order a Dexter axle with the shock bracket. There are some critical measurements you have to do for Dexter to get an axle that will fit. Inland RV and I think Colin Hyde have the dimensional information. It might help if you can have a Forums member or an Airstream dealer check it out for you. Maybe even take her to the mothership at Jackson Center, IN.
Old 10-18-2016, 09:01 AM   #16
1972 27' Overlander
Denver , North Carolina
Call Colin his axles ship with everything you need.
Lucky Dave, Denver NC
mccrosti is offline   Reply With Quote
Old 10-18-2016, 11:48 AM   #17
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
As mentioned above, do look at balancing the tire/wheel assembly. If not balanced well, even small shaking of the tire/wheel assembly will do a number on the entire trailer.
New shocks will help dampen an out of balance tire/wheel assembly (and any other smaller vibrations) however shocks are not designed to over come worn out parts (axles) and out of balance wheel assemblies.
The issue may be a combination of items not confined to just one thing.
>>>>>>>>>>Action
Old 10-19-2016, 07:36 AM   #18
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
You can also pull the old axle and take it to your nearest Dexter axle dealer. The dealer will take the critical measurements. They can order you the axle directly.
Take these documents with you for reference. The differnce between a #10 and #11 axle will be size of the axle tube, spindle size and brake drum size. Also look at the tag on the side of the trailer. This will have the axle weight rating. You will need this number when ordering a new axle.
PM me if further info needed. I have been thru this a few times.
03308801[1].pdf
E_1492.pdf
E_1493.pdf
E_1501.pdf
Hensley with adjustable stinger
WBCCI # 3072
crispyboy is offline   Reply With Quote
Old 12-23-2016, 01:22 PM   #19
1980 20' Caravelle
Coeur d alene , Idaho
Replace Axle
I own a 1980 20 foot Caravelle, replaced the axle in October--ordered it from Colin. Only had to enlarge the hole on the shock mounting bracket--rest fit perfect--Colin has the measurements!! Trailer tows better not alot of movement inside! Don
glacierrunne is offline   Reply With Quote
2 questions about lcd installation. Speakers and vibration mikeandnora Audio, Video & TV 5 05-04-2011 07:08 AM
Tranny Tailshaft Vibration? swebster Mechanics Corner - Engines, Transmission & More... 31 02-22-2006 06:33 PM
Intermittent Chassis Vibration Chaplain Kent Mechanics Corner - Engines, Transmission & More... 29 10-29-2005 09:49 PM
Furnace Vibration and Noise flyfisherman Furnaces, Heaters, Fireplaces & Air Conditioning 3 10-16-2005 07:37 PM
1997 "B" generator vibration & noise TuckerT Sprinter and B-van Forum 0 10-06-2004 06:42 PM
