Old 11-11-2008, 05:50 PM   #1
Central , Mississippi
Upside down trailer and axle pieces
Ok, so the title is slightly misleading....
I'm going to use one of my old axles under a farm trailer and had to narrow it 5.5 inches for the best fit soo...
I flipped over the farm trailer...
And sawed a section out of the center beam...
And thought the interior of the axle might be interesting to some of ya'll
none of the rubber rods are completely wiped out but it does appear that they have squirmed into an unusual position.
ID:	71286   Click image for larger version
ID:	71288   Click image for larger version
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 11-11-2008, 05:52 PM   #2
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
The rods are where they are supposed to be. We have a display here, and the rods in it are where they are in yours.
Old 11-11-2008, 06:15 PM   #3
Alumanutz's Avatar
1966 22' Safari
Chico , California
Terry, please explain. From what I can see, it appears that the rod at 12:00 is nice and round, the ones at 3,6 and 9:00 seem to be smashed by half.
NUTZ
View my Airstream Blog at www.alumanutz.blogspot.com
Grown men, dressed as clowns, concern me.
Alumanutz is offline   Reply With Quote
Old 11-11-2008, 07:39 PM   #4
Originally Posted by Alumanutz View Post
.. it appears that the rod at 12:00 is nice and round, the ones at 3,6 and 9:00 seem to be smashed by half.
NUTZ
That was kinda my observation. 3 were malformed and squished into a strange shape and 1 seemed to be round. It makes me wonder if the failure mode was the rods got rolled into a pinched shape and simply couldn't unwind.
I was surprised at how rubbery they still seemed.
No rivits to pop loose in they new trailer
Old 11-11-2008, 07:42 PM   #5
mustang's Avatar
1986 31' Sovereign
Kent , Ohio
Very good illistration. that explains alot on these axles.
Are those Henschen or Dexter?
Did they come off your Airstream?
And last but not least. What year are they from?
That is a great view
mustang is offline   Reply With Quote
Old 11-11-2008, 07:44 PM   #6
1977 axles, Henschen, original axles on my 'stream
Gotta thread somewhere on the axle folder
Old 11-11-2008, 07:44 PM   #7
mustang's Avatar
1986 31' Sovereign
Kent , Ohio
Inlight of that crushing.. 2 are in good shape.
I would surrmise its because they were not load bearing at the time of the photo. Otherwise it would seem a bit weird because I would think the 2 good ones would be carrying the brunt of the weight.
Old 11-11-2008, 08:10 PM   #8
Well Preserved
1993 21' Sovereign
I was on the way out the door when I posted the above. They are where they are supposed to be, even though "squished".
Old 11-11-2008, 08:20 PM   #9
jpeterman's Avatar
1972 27' Overlander
Graham , North Carolina
thanks, I learned a little with nthis post
the trailer axle was a mystery to me until that cut out
thanks again
jerry
"AIR 17559"
wear it out, don't rust it out
Jerry
jpeterman is offline   Reply With Quote
Old 11-11-2008, 09:58 PM   #10
The rubber rods appear deformed, but I think they are not, since it was a matter of the angle of the photo, as evidenced by the shadow to the right of the shaft, which suggests that the camera was not straight on.
If the steel shaft cannot be removed easily from the square tube, then the axle, while being shot for it's original intended use, still can be used for far lesser weight loads.
We have numerous requests for old axle sales from people that want to make a small utility trailer.
A 3000 pound or more old axle, that still has a little life in the rubber rods, works sort of OK, for small light weight utility trailers.
We usually give them away.
Old 11-12-2008, 06:49 AM   #11
If the steel shaft cannot be removed easily from the square tube, then the axle, while being shot for it's original intended use, still can be used for far lesser weight loads...
Out of the 1/2 dozen trys to wiggle the lens and flash into a good angle for the photo, that one gave the best representation of what the rubber inserts actually looked like.
The 12 o' clock rod is basically round, 3 and 9 are semi squished/twisted and the 6 o'clock one is almost the shape of a shrimp and bound in position.
It was explained to me in a PM-
"the axle design in your pic was tried for a few years as an "improvement" to the older design. when it proved to be NO better and perhaps LESS good, they went back to the older design, which is a square rod inside, NOT the toothed/hooked version like the one in your picture"
I'll let the PM'r post and take credit for the info as he see's fit
Parts and Pieces SwampBillies General Repair Forum 13 09-09-2007 04:29 PM
One or Two pieces? Safari Tim Repairing/Replacing Floor &/or Frame 6 07-16-2006 10:43 PM
May it rest in pieces. RichardT Classic Motorhomes 12 04-19-2006 12:36 PM
use of mobile home axle on road trailer tom967 Axles 7 11-26-2004 05:32 AM
Jack for a 3 axle trailer dmreilly10000 Axles 2 01-07-2003 12:27 PM
