11-01-2010, 12:54 PM
1997 34' Limited
1970 27' Overlander
South of Atlanta
, Georgia
Upgrade replacement axle rating for 1997
I need to replace the axles on our '97. The original axles are rated at 3200#. Is there any downside to buying higher rated axles? 4000# maybe. Would the higher weight rating result in a harsher ride for the trailer?
Also along the same lines, I understand one of the factors in early axle failure is lack of use (the rubber rods need to be exercised). Since the factory has been shut down for some time now, are the current inventory of axles deteriorating on the shelf like tires?
Craig and Carol
1997 34' Excella 1000
1970 27' Overlander, International
2009 Ford F150 5.4L
ProPride hitch with 1400# bars
AIR 41028
TAC GA-8
WBCCI 10199
Past President Southeastern Camping Unit (12)
11-01-2010, 01:47 PM
1971 27' Overlander
Antlers
, Oklahoma
Andy R. would be the one to answer these questions. Hopefully he will be on later - or you could PM him.
Mel
2006 GMC 1500 SLE Crew Cab
5.3L V8 Towing Package
Equal-i-zer E2
AIR # 40365
TAC # OK-3
11-01-2010, 02:08 PM
Corona
You can go to 3500 pounds without any problems.
However, if you want to go to 4000 pounds, then without except, the trailer must be heavily loaded for every trip.
Yes, if any torsion axles just sits for s few years with weight on it, the rubber rods will give out.
Rubber anything, must be exercised periodically, or else. Even rubber bands.
11-01-2010, 03:02 PM
Port Orchard
[QUOTE=Aviator;912623]
QUOTE]
What does this refer to?
Regards,
Ken
11-01-2010, 03:15 PM
1986 25' Sovereign
Plant City
[QUOTE=w7ts;912668]
QUOTE]
Regards,
Ken
The factory closed some time back and I believe Andy has all there stock. There was talk about them reopening but I have not heard anything about that lately.
I am sure he will chime in with updates/details.
Chris
11-01-2010, 03:25 PM
Port Orchard
Chris
OK, the Henschen Axle factory. I though he meant Airstream factory.
Can new Dexter Axles be used?
Ken
11-01-2010, 04:14 PM
_
if the current axles are shot, ride should improve with ANY new set, even higher rated axles.
the relevant questions are these ...
1. is there any UPSIDE to buying higher rated axles?
2. is there any downside to buying axles from a discontinued/closed manufacturer ?
working backwards...
it is wacky to think about buying new axles and PAYING new prices for a product that's been discontinued.
there is a list of reasons for this.
_______
dexter is still in biz and still making axles.
they can be purchased from 100s of vendors close to home,
including the service center in j/c.
IF new hubs are part of this, the option exists for sealed bearings and/or disc brakes...
all can be had at a very competitive price and for LESS $ than old stock henschens with the same bits.
________
dex' (and other makers) will have 3500 or 3800 or 4000 lb axles.
35/3800 might be a good choice.
one can also select another starting angle IF more clearance is needed or wanted...
for example IF considering 16 inch wheels/tires.
________
another UPSIDE to having higher rated axles installed in j/c is
that they MIGHT be willing to RE certify yer stream for more cargo carrying capacity.
another good thing.
__________
unless you intentionally plan on loading up the stream with lots of stuff, 4000 lb axles x3 seems 2b a bit much.
but 35 or 3800 lb axles would be good choices.
cheers
2air'
11-01-2010, 05:03 PM
1997 34' Limited
1970 27' Overlander
South of Atlanta
, Georgia
I spoke with Andy and got my questions answered. The biggest one was the upgrade in capacity. He suggested that unless I was always fully loaded the 4000# would be too much. Since I am a weekend camper at this point; I am always well under the rated 9600# for the trailer.
My original thought on the 4000# was that if I had a flat and was only supporting the trailer fully on two of the three axles while I limped to an area for a replacement tire, the remaining two axles would not be overloaded.
My normal trailer weight at this point is around 7800#
Craig and Carol
2009 Ford F150 5.4L
AIR 41028
TAC GA-8
WBCCI 10199
11-01-2010, 09:13 PM
Airstream - Other
Bosque Farms
, New Mexico
You know, it just seems a bit premature for you to need new axles on a 97 rig. We replaced ours last year on our rig, and it is right at 30 years older than yours. Are you sure they're bad?
Lynn
ACI Big Red Number 21043
11-01-2010, 09:25 PM
1977 31' Sovereign
1989 34' Excella
Johnsburg
Even if you have a large load on, stiff axles are stiff axles and will give the trailer a harsher ride and potentially more damage on a rough road. The more flexible axles will take up more of the shock and transmit less of it to the trailer. Airstream engineers take this into account when they design the trailer. The shocks on the Airstream trailers (which are not commonly used on other SOB trailers) also absorb some of the shock.
11-01-2010, 10:33 PM
1977 31' Excella 500
West Sacramento
I upgraded from original 4000lb axles to 4500lb henschens at Inland and the ride is good after 1500 miles. My trailer weighs 7500lbs and Inland suggested I go a bit higher on the axle rating. Trailer sits higher now than when it was new. My rear end has not scraped the pavement since the replacement.
11-02-2010, 10:35 PM
St Cloud
Anyone else ever pondered this FAQ from the Dexteraxle site?
TORFLEX - Can I use 3 Torflex axles under my trailer?
No, Dexter does not recommend triple Torflex applications because Torflex axles are totally independent and not equalized like a typical leaf spring set of axles. There is no ability to transfer loads from one axle to another. When traversing uneven operating surfaces such as driveway entries, railroad crossings or speed bumps, the entire load can be put onto one axle causing severe overload. It isn't reasonable to expect one axle to carry the entire load of three axles when these conditions occur, even though these instances cause only momentary over-loading.
11-03-2010, 04:17 AM
1977 31' Sovereign
1989 34' Excella
Johnsburg
It seem like a good question for the engineers at Airstream, who first designed the 34 foot trailer with triple axles back in 1984. I would have thought they considered it and made some calculations to justify their conclusions. Of course, they were not using Dexter axles at that time and Henchen may have taken a different viewpoint. There is a limited amount of compliance in all axle systems. If the dip is deep enough, that wheel will not help carry the load and the load will be carried by the remaining five wheels. That is why, you can take a wheel off (when absolutely necessary) an Airstream and still continue down the road.
11-03-2010, 06:48 AM
1997 34' Limited
1970 27' Overlander
South of Atlanta
, Georgia
Lynn,
Unfortunately, yes I am sure I need new axles. I have followed all the "checks" in the threads on axles that I could find on the forum. The best that can possibly be said for them is that they are marginal. As a consequence of my profession, I can't abide marginal when it relates to a piece of equipment. While I have other uses for the $$, I don't want to wait on replacing and incur damage to the trailer through lack of suspension and the resulting rough ride.
As an added benefit of replacing the axles, I expect the trailer to ride somewhat higher. For me that means not grinding of the drag plates at the rear of the trailer each time I back it up my driveway to work on it. This will also make my wife happy since it leaves marks in the concrete. I don't like the bending stress it puts on the trailer frame.
Craig and Carol
2009 Ford F150 5.4L
AIR 41028
TAC GA-8
WBCCI 10199
12-26-2010, 07:01 AM
1999 34' Excella
Joshua
It does seem that axles on your '97 are already needing to be replaced...
History doesn't repeat itself, people do!
12-26-2010, 07:12 AM
1997 34' Limited
1970 27' Overlander
South of Atlanta
, Georgia
I finished mounting them on Christmas Eve. I went with 3500# Henschen axles. The trailer rides between 2 3/4" and 3" higher. the best part is the axles now flex. The original ones were totally frozen in position from sitting in one spot for 10 years.
Craig and Carol
2009 Ford F150 5.4L
AIR 41028
TAC GA-8
WBCCI 10199
12-26-2010, 08:28 AM
Ottawa
, ON
As far as the dragging is concerned, a couple of 2"X10" laid in the low spots will cure that, won't they?
For further protection, grease up a sheet of 1/4" ply to put where it scrapes, if the 2"x10" doesn't give enough of a raise.
If your profession will allow, that is
Otherwise, apply money liberally.
“Courage is being scared to death, but saddling up anyway.” ...John Wayne...........................
12-26-2010, 08:59 AM
Corona
Dragging the rear end of any Airstream trailer, is bad.
Typically, the rear quarter panels are buckled, which then requires replacement.
Then the next problem is making the shell flex, in the wrong direction. Flexing down is ok to a point, but flexing up, creates a number of problems, starting with the furniture and shell.
Not to mention damage to a driveway.
12-26-2010, 11:11 AM
1997 34' Limited
1970 27' Overlander
South of Atlanta
, Georgia
Andy,
The drag (I should have written scrape was minimal) Had I had another 1/16 in clearance it never would have touched the drive, and most of the time didn't. However, I no longer need to be concerned with that issue with the new axles. Now I have room to spare!
Craig and Carol
2009 Ford F150 5.4L
AIR 41028
TAC GA-8
WBCCI 10199
12-26-2010, 11:32 AM
Corona
Andy,
Pilots always like that extra space, be it taxiing or with an Airstream. YEAH
