Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Axles
Old 09-13-2009, 01:36 PM   #1
Profile:  1964 19' Globetrotter
tucson , Arizona
uneven tire wear
just returned from a cross country trip 11k miles on a new set of 15"
radials.. (dico 225/r75 load range e)...i have a new duraflex 5000lb axle...
i have noticed extreme tire wear on the outside edge of the tires on both the left and right tires...tire pressure is ok and the trailer tracked like a laser at all speeds... could this be a toe-in problem with the axle....????
1964 19' globe trotter
2000 dodge 1ton cab chassis 4x4
19.5 rickson rims / banks / edge chip
mark miceli
tucson az
64globetrot is offline   Reply With Quote
Old 09-13-2009, 02:23 PM   #2
snake's Avatar
Profile:  1994 21' Sovereign
1999 19' Bambi
Tucson , Arizona
Sounds like tread separation.
snake is offline   Reply With Quote
Old 09-13-2009, 02:23 PM   #3
Doohickey's Avatar
Profile:  2009 19' Flying Cloud
Bordentown , New Jersey
That's what I was thinking. Had a car one time that had the same issue and it was determined to be the toe alignment. How that could that be on a trailer I don't know. How they fix it on a trailer I don't know.
Doohickey is offline   Reply With Quote
Old 09-13-2009, 02:39 PM   #4
Profile:  2007 19' Bambi
Peoria , Arizona
They do align trailer axles
Gil Reinke is offline   Reply With Quote
Old 09-13-2009, 03:01 PM   #5
jimmickle's Avatar
Profile:  Marion , Iowa
Toe is easy to check with a ball of string and four jack stands. Set up string between two jackstands on each side of the trailer. Measure out from the center of the trailer to the strings on each side, making the dimensions equal by moving the jack stands as required. Once you have the string set up parallel at hub height, just measure from the string to the wheel front and back. Racers align race cars like this all the time
jimmickle is offline   Reply With Quote
uneven tire wear!! claybags Tires 34 01-13-2009 01:28 PM
Tire wear carlj Tires 2 05-03-2008 04:50 PM
Uneven tire wear..Yikes!! daydreamer36535 Tires 18 07-09-2007 11:17 AM
Cupping tire wear, Why? Ganglin Tires 2 02-05-2007 07:52 AM
Un-even tire wear Deputych Tires 5 05-15-2003 01:23 PM
