Old 01-24-2003, 07:42 PM   #1
Talking trailer hitch height '68 Sovereign
Hi,
I'm getting ready to tow my newly purchased '68 Sovereign. At present it is far away from where I am. If anyone could let me know the height of the hitch it would be helpful as I want to get the right ball. The towing vehicle is a '86 Ford 250 pick-up.
Many thanks,
Nicholas
sectionc is offline   Reply With Quote
Old 01-24-2003, 07:56 PM   #2
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
19
nineteen inches. according to airstream web site.
you can find the info here
john
Old 01-25-2003, 03:04 PM   #3
There is no correct hitch height for any Airstream trailer.
There is, however, a design dimension.
That dimension will vary considerable, depending on the condition of the axles, AND, how much payload is in the trailer.
A variation of almost 3 inches, from the designed height, is not uncommon.
inlandrv.com
airstreamparts.com
airstreamcandy.com
Old 01-25-2003, 03:12 PM   #4
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
good point
andy
as always, good point.
but the nineteen inch measurement would be a good starting place.
john
Old 01-25-2003, 03:18 PM   #5
Not on a 68.
inlandrv.com
Old 01-25-2003, 03:34 PM   #6
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
ok
andy
ok, other than actually going out and measuring it what would you suggest?
the reason i ask is because i may have to tow a 68 ambassador soon. i see from the airstream pdf file the height is listed as 19 also.
waddya think?
thanks
john
p.s. 2 inch ball on these right?
Old 01-25-2003, 04:18 PM   #7
John.
2" ball is correct, unless someone changed the coupler.
I would suggest that you start with no more than 17 1/2 to 18 inches.
inlandrv.com
airstreamparts.com
airstreamcandy.com
Old 01-25-2003, 08:11 PM   #8
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
balls!
andy
thanks for the info, as near as i can tell the coupler is original.
john
Hitch height Chuck Hitches, Couplers & Balls 20 04-09-2016 10:21 PM
Hitch Ball Height RivetED Hitches, Couplers & Balls 4 03-21-2004 08:25 PM
truck mods & hitch height changes silverback Hitches, Couplers & Balls 13 12-31-2003 07:54 AM
Raising Trailer Height John Sims Axles 2 06-24-2003 10:52 AM
tow hitch height using a 1960s car oldvws Hitches, Couplers & Balls 15 11-27-2002 03:43 PM
