Old 02-21-2004, 08:16 AM   #1
Over59's Avatar
Putnam , Connecticut
Images: 37
Towing without walls
Can an AS be towed a thousand miles without interior walls. I think this would be a major structural problem.
Over59 is offline   Reply With Quote
Old 02-21-2004, 08:37 AM   #2
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
Are you talking about inner skin, or divider walls?
Without divider walls would mean that most of the built in's would also be loose or gone. I don't think that's a problem, whatsoever.
Without the inner skin,the trailer would be structurally much weaker. I would not tow without the inner skin, definitely not 1000 miles.
Uwe
www.area63productions.com
Old 02-21-2004, 08:59 AM   #3
Over59's Avatar
Images: 37
Inner skin is gone on the 68 Sov and the poor guy put it in the trash. Agree it's a bad idea, just thought I would put it out there for feedback.
The 56 Overlander ( dream machine ) has inner skin any noting else. This I think would be OK but would likly add some internal supporting braces. If only Washington was closer to Connecticut.
Know anyone in Washington who would like to make a few bucks checking out a trailer???
Old 02-21-2004, 09:31 AM   #4
5 rivets, 1 loose screw
Rog0525's Avatar
1966 20' Globetrotter
Saginaw County , Michigan
Images: 11
Check out rluhr's VOLUNTEER INSPECTOR list.
There are several volunteers in Washington.
Rog
Rog0525 is offline   Reply With Quote
Old 02-21-2004, 03:43 PM   #5
LOST , Hawaii
I bet you can make it ok. If you are worried about it run a 2x4 down each wall about halfway up and 2 or 3 braces from that to the floor on the opposite side. The shell is still attached to the floor and frame so it should be pretty strong. The real strength in the shell is in the outer skin being buck riveted to the ribs. The inner skin and pop rivets are not nearly as strong.
John
74Argosy24MH is offline   Reply With Quote
