Old 03-16-2009, 09:50 AM   #1
1968 28' Ambassador
Torsion vs. Leaf Spring Axles
Hi all,
I just towed my '68 Airstream Ambassador into a welding/trailer shop to have them give me a quote on axle replacement. Their initial take was to install leaf spring axles instead of new torsions. Their arguments were:
  • Easier maintenance/replacement
  • Smoother ride over rough roads
My criteria for axles are:
  • Safety
  • Reliability/Maintenance
  • Smooth ride
  • Cost (upfront and maint.)
I'm not concerned with preserving the original look of the axles.
What is everyone's opinion on what axle type better? Are there negatives to switching to leaf spring axles?
Steve
‘68 Vintage Airstream blog
air-austin is offline   Reply With Quote
Old 03-16-2009, 10:04 AM   #2
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
Find another shop..............
Old 03-16-2009, 10:10 AM   #3
Originally Posted by air-austin View Post
Hi all,
  • Safety
  • Smooth ride
Steve
Steve.
Airstream switched to "torsion axles" for four reasons, back in 1961.
1. Torsion axles provide a much softer ride than any spring setup, leaf or coil, could every provide.
2. Each wheel is independent from the others. What may happen to one wheel on one side of the trailer, has no effect on the other wheel or wheels on the same side.
3. You can easily remove a tire and wheel from one side, and continue on, without the need to "tie up a spring".
4. "ZERO" maintenance.
Your shops three arguments are invalid.
1. There is nothing to maintain, with a torsion axle. Not so with spring suspension.
2. Four "U-bolts" hold up a single spring type axle. Those four U-bolts use 8 nuts, 4 U-bolts, 8 washers and 8 lock washers. A torsion axle is held in place with less than "half" that hardware.
3. Hundreds of Airstream owners would quickly attest to the smooth ride that torsion axles provide, over all types of surfaces.
Sorry, but your guy obviously does not have much "torsion axle" experience or knowledge.
Old 03-16-2009, 10:18 AM   #4
87MH's Avatar
1978 31' Sovereign
Images: 292
I'll bet that welding shop was not a torsion axle dealer of any kind.
Usually the torsion axles are touted as having the softer ride.
I would stay with the torsion axles, and by all means, get a quote from several shops.
Replacing the original axle with a new torsion axle is not that hard of a job, you should really consider doing it yourself.
There are several shops in your area that are capable of working on Airstreams - you can bet a hole punched in your belly pan that most tire/welding/camping type of stores ARE NOT to be trusted with an AS product - too many horror stories.
Bottom line, if you have to "pay" someone to come up to speed on the learning curve, you are either better off doing it yourself or paying a few extra bucks to a shop which is already Airstream Friendly.
It may be a bit far for you, but Bob Jones RV Repair (Bob Jones RV) has been repairing Airstreams for the last two decades. Their shop is located in SE Houston, close to Hobby Airport.
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign
Texas Airstream Harbor, Inc.
Old 03-16-2009, 10:22 AM   #5
CanoeStream's Avatar
St. Cloud , Minnesota
pre-1961 Airstreams on OEM leaf springs rode at a nice height. I've seen photos posted of somebody who replaced springs on his '56 with leaf springs of unknown origin. You can see how ungainly high it rides. Destroys the whole look IMO. Here's a link - http://www.airforums.com/forums/atta...7&d=1148014858
5 meter Langford Nahanni
Old 03-16-2009, 10:33 AM   #6
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
I agree...find another shop. Torsion axles are far better than spring axles. I have both (Airstream torsion, boat spring). Night and day difference.
Old 03-16-2009, 10:46 AM   #7
silverleeper's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Images: 8
Hi all,
  • Safety
  • Smooth ride
Steve
Hi Steve, Take a look HERE and keep a open mind. Axle threads provoke allot of passion in some members. I don't agree with changing from torsion to leaf spring just for the fact that your frame is designed for a torsion axle. Your axle shop will have to do allot of extra fabrication and welding that you will be paying for. This work if not done right will cause you allot of grief in the long run. You can replace a torsion with some ease. I've done it and many others have too. You will get lots of help on this if you ask.
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Old 03-16-2009, 12:47 PM   #8
Silverwanabe's Avatar
1967 26' Overlander
Winston Salem , North Carolina
Images: 107
IMHO, torsion rubber axles have always been seen as superior to the old fashioned leaf springs.
Greg
Winston Salem, NC
WBCCI 5218,
Corresponding Secretary Piedmont NC Unit 161,
1967 Overlander International.
1979 Avion 30ft rear bath
TV's 88 Chevy Suburban 454, 3:42, TH400
95 Cadillac FW Brougham, LT1,3:42, 7k tow pk.
Silverwanabe is offline   Reply With Quote
Old 03-16-2009, 02:32 PM   #9
Images: 59
My opinion is a little different than those above. I believe that properly designed leaf springs CAN give a smooth and gracious ride. They are less expensive, and can be easily serviced anywhere.
I am very pleased with the leaf springs in my single axle '59 Tradewind.
On the other hand, switching to leaf springs from a torsion axle is probably not a good idea. You need to beef up the frame where the spring hangers mount. You'll need to get 4" drop axles. Most of all, you need to have the axles designed and fabricated by a reputable spring shop that can give you the correct spring rate and length. I wouldn't use the stock utility trailer springs like you find at TSC or Northern Tool.
Old 03-16-2009, 02:46 PM   #10
SilverHoot's Avatar
1967 24' Tradewind
Greenville , South Carolina
How about longevity? Seems the torsion axles have a shorter lifespan?? But I'm with Markdoane, if it came stock with torsion I would go with torsion.
SilverHoot is offline   Reply With Quote
Old 03-16-2009, 02:47 PM   #11
I'm familiar with the shop where Air-Austin has his trailer, and they are a Dexter axle dealer so they certainly have access to torsion axles. They have been fair and reputable in my dealings with them, but I suppose it's possible they are trying to persuade their customer toward the sprung axles in order to sell their welding/fabrication services.
They work on a LOT of trailers there, though mostly flat-bed cargo trailers rather than RV trailers, so perhaps that experience is why they might tend toward the sprung axles, I really couldn't say.
Anyway, they've done good work for me in the past, and in a timely manner, at fair prices, so I don't have any reason to doubt them.
I'll be interested to see what they come back with as quotes.
Old 03-16-2009, 03:47 PM   #12
1972 Travelux Princess 25
Cobourg , Ontario
New torsion axles are so cheap and easy to install it has to be cheaper to replace them than to change to leaf springs.
I wouldn't put in leaf springs. They are OK but you have nothing to gain by doing so.
Living in the trailer park of sense, looking out the window at a tornado of stupidity.
Ganaraska is offline   Reply With Quote
Old 03-16-2009, 04:11 PM   #13
1968 28' Ambassador
Thanks for all of the great feedback so far. It's great to get everyone's opinion. I'm certainly more educated about axle differences since this morning.
I'm awaiting some pricing from the shop. I'll post again when I get their assessment and let all of the local Austinites know if I need a hand replacing these axles...
Old 03-16-2009, 05:35 PM   #14
Cobourg , Ontario
The only kick I can think of against the torsion axles is that the rubber gets hard and takes a set, then you have to replace the whole axle. Leaf springs are immune to this.
However it seems to take at least 20 years for this to happen and new axles are only around $300 bucks apiece. So it doesn't seem so unreasonable.
axle, leaf spring, torsion
Leaf spring suspension grommets Scott S Axles 10 06-02-2008 07:26 AM
Leaf Spring Assist for my TV Paul NC Tow Vehicles 2 01-12-2007 03:14 AM
How many leaves in a leaf-spring axle??? 1959newbie Axles 20 08-05-2006 04:53 PM
Leaf Springs vs. Torsion Axles JimGolden Axles 11 01-19-2006 01:16 PM
Torsion axles Silvertwinkie Axles 4 01-29-2004 08:18 AM
