Old 08-22-2011, 08:44 PM   #1
Anchorage , Alaska
Thoughts on a Trailing Arm Axle/Suspension
Well, after lirking and researching on the forum for about a year. Decided to pull the trigger and buy my first trailer.
http://www.airforums.com/forums/f16/so-it-begins-80649.html
The trailer still has the original axle and split rims. I fully expect to do a full monty shell off, and will likely have some rust repair before the frame will be ready to slip back under the shell
Living in Alaska, I do a lot of camping, year around, but to be honest not sure if I have ever spent a night in a trailer. (there was a 5 week period this summer where I spent 3 weeks in my tent !!)
I would be curious as to the more experienced opinions in the forum of a trailing arm axle system under a travel trailer.
http://www.adventuretrailers.com/suspension.html#airbag
I would fully expect to reinforce the frame. And to be clear, I have no ambitions to try and take a travel trailer "off roading". But the roads in Alaska suck. The dirt roads are usually in better condition than the paved roads! One of the grandkids favorite camping trips is a few miles down the beach.
Aktundra is offline   Reply With Quote
Old 08-23-2011, 08:36 AM   #2
Aluminum Falcon Mechanic
Darkspeed's Avatar
1972 31' Sovereign
Wesley chapel , Florida
They are super easy to build. Not so super easy to align. I have built these before but rather used threaded tube ends and threaded rod ends to have some degree of adjustability. I used Airride bag over shock for mine.
Darkspeed is offline   Reply With Quote
Old 08-23-2011, 09:14 PM   #3
Anchorage , Alaska
thanks darkspeed. I have come across some of the same concerns with how difficult this apprach can be to align.
Have you seen any web links or reccomend someplace I could continue my reasearch on the adjustable axles?
Old 08-23-2011, 11:08 PM   #4
Darkspeed's Avatar
1972 31' Sovereign
Not really I designed my own.
In your photo they used two red poly bushings as the pivot points so adjustment is minimal. I used 4130 tube and weld in threaded tube end inserts. I installed 4130 rod ends and jam nuts in the tube ends. This allowed for any type of adjustment you could imagine. Rather than use a bag and a shock I used the double adjustable shock cartridge with a Goodyear air spring.
Old 08-24-2011, 11:12 PM   #5
Anchorage , Alaska
actually those pic's are very helpful. When you said adjustable, I was trying to visualize something down at the bottom of the arm. This makes much more sense. Obviously I have a lot more research to do, to find something afforadable.
Old 08-30-2011, 01:44 PM   #6
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
In my opinon the modern Airstream isn't a good choice for rough service. An early 60's unit like your may be a better choice as far as heavier built components. The general design doesn't adapt to rough service. A full frame on design would be a better choice versus the existing design where the body is an intregral part of the structure.
>>>>>>>Action
Old 09-07-2011, 10:19 PM   #7
Anchorage , Alaska
Thanks for the input Action. I need more input from those with more experience
I am very inexperienced with travel trailers, and I am rarely accused of good judgement.
The Airstream Gods have intrusted me with a Bambi. I hate to blow it
Old 10-09-2011, 06:28 PM   #8
1974 23' Safari
Pointe Claire , Quebec
How about a upper and lower table system, GM truck style/ Hummer?
Streamtrain is offline   Reply With Quote
Old 10-10-2011, 04:54 PM   #9
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Or the walking beam suspension used by AVION circa 1968-1977 (see HENDRICKSON). Called it Smooth-Glide" engineered and built by MOR-Ryde. More links to these names on this forum, and the M-R website.
DEXTER is now making an air-over-torsion axle. "Flex-Air" or some such name.
Lateral Arm Awnings crazeevw Classic Motorhomes 5 08-28-2011 07:22 AM
Thoughts on condition of tank? MrJ LP Gas, Piping, Tanks & Regulators 4 07-19-2011 02:01 PM
50's Hehr roof vent lifter arm rivet tool vintageair Roof Vents, Skylights & Fans 12 06-29-2011 01:37 PM
Need thoughts on battery draw Airslide Batteries, Univolts, Converters & Inverters 11 04-08-2011 08:44 PM
Help with installing new claw arm Sadie08 Awnings 3 01-24-2011 09:39 AM
