Old 09-23-2010, 11:16 PM   #1
pawnguy's Avatar
2005 30' Safari
Joplin , Missouri
Lightbulb Testing bearings.
Just bought a 1975 31 foot AS. I've seen where people talk about putting in new axles... Is the a must if the bearings and axles look good or just something that needs to be done??
A Real Pawnguy... "when life gives you lemons, make lemonade"
pawnguy is offline   Reply With Quote
Old 09-23-2010, 11:18 PM   #2
pawnguy's Avatar
2005 30' Safari
Joplin , Missouri
Not sure how to search to see if this has been asked already.. Sorry if it has been..
Old 09-24-2010, 12:48 AM   #3
Maniacal Engineer
barts's Avatar
Menlo Park , California
Here's the scoop:
Dura Torque Axle
I replaced our '71 Tradewind's axles, and the trailer rides several inches higher as a result, and when I move around inside, it rocks and sways on its suspension.
Check the angle that the suspension arms make w/ the horizontal as described in the link...
- Bart
Bart Smaalders
Menlo Park, CA
http://tinpickle.blogspot.com
http://smaalders.net/barts
barts is offline   Reply With Quote
Old 09-24-2010, 01:04 AM   #4
NevadaGeo's Avatar
1978 31' Excella 500
Genoa , Nevada
That's a very good read Bart. Pawnguy, you'll almost always be needing new rubber torsion in a 35 year old trailer, which means new axle assemblies. And, if your Soverign has disc brakes, don't let anyone talk you out of them for some older style drum brake. You'll be glad you keep the disc brakes down the road.
What's the oldest "good" rubber torsion bars axles anyone knows of?
Perry
I admit to being powerless over housecleaning and social niceities
Airforums 22655 and now, WBCCI 22655
NevadaGeo
NevadaGeo is offline   Reply With Quote
Old 09-25-2010, 10:48 AM   #5
Perry
Perry.
Actually not "good" but still serviceable (barely), we found to be almost 50 years old. A rarety indeed.
However, that one trailer was used weekly, which obviously help considerably.
Under normal use, the estimates call for 25 to 30 years, as long as the coach was moved frequently, like every 6 months or so.
The biggest killer, is "lack" of use.
Those rubber rods must be exercised, or else.
Like they say, "use it or loose it".
Old 09-26-2010, 09:01 PM   #6
NevadaGeo's Avatar
Genoa , Nevada
Originally Posted by Inland RV Center, In View Post
Perry.
Thanks Andy! Now lets turn the question around, what's the shortest time folks have been able to kill their axle investment, say in dis-use?
NevadaGeo
Old 09-26-2010, 10:05 PM   #7
We have already replaced axles on a few 2008 models.
I feel that was because of overloading due to under rated axles and/or overloading.
Non use, typically takes about 3 years or so, with the total weight still on the axles.
When the trailer is not going to be used, and is totally supported by jack stands, then the non-use time can go to 10 to 12 years or so.
Keep in mind, that rubber must be exercised to stay alive.
Old 09-27-2010, 03:35 PM   #8
Cracker's Avatar
Pittsfield , Maine
That brings up an interesting question. Should the trailer be supported off the tires on jacks for the typical 6-month winter lay up??? To date I've never done it - out of fear that I would get a severe case of cabin fever and have to head south in the middle of a snowstorm!!!
Cracker
Cracker is offline   Reply With Quote
Old 09-27-2010, 07:49 PM   #9
It's best to store the trailer, with zero weight on the tires.
But.................if you need to make that sudden "get away" during the winter snowy months, then I guess the only thing you can do, is start off with the snow shovels. Yuk.
axle
a/c testing how-to strmstr69 Furnaces, Heaters, Fireplaces & Air Conditioning 7 11-05-2008 07:58 PM
Testing Canuks 2002 - 2005 International 10 03-17-2005 07:30 AM
