Old 08-16-2016, 07:33 PM   #1
The Colonel's Avatar
2017 25' Flying Cloud
Navarre , Florida
Suspension tube damage?
I crawled under my 2017 25' FC to check on a creak in the floor and saw a 3" square tube that connects left and right suspension sides together, I think. While looking at the tube it was bent up towards the middle slightly as if it had been jacked at that point. Not greatly distorted, but enough to see the tube was distorted. Is this something I should go back to dealer with or nothing to be concerned with?
The Colonel is offline   Reply With Quote
Old 08-16-2016, 07:44 PM   #2
66Overlander's Avatar
1962 22' Safari
2016 30' Classic
Somewhere , in the USA
Images: 41
What you saw is normal. That bend is part of aligning the wheels.
That said, never jack the trailer by the axle tube or you can cause damage.
Joe
WBCCI/VAC #6768
66Overlander is offline   Reply With Quote
Old 08-17-2016, 06:08 AM   #3
Navarre , Florida
Thanks, glad I asked.
How do I clean my AC drain tube? tyndalelady Furnaces, Heaters, Fireplaces & Air Conditioning 67 05-13-2013 11:55 AM
? carter shade awning roller tube retro-active-couple Awnings 3 06-23-2004 03:56 PM
Fresh water filler tube '63 Safari srgntpepper Fresh Water Systems 5 05-27-2004 07:16 AM
Tube type tires for 77 alum rims Mike B Tires 10 04-09-2003 08:04 PM
