Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Axles
Old 06-28-2005, 12:36 PM   #1
MarkR's Avatar
1951 21' Flying Cloud
1960 24' Tradewind
Folsom , California
Images: 12
straight or dropped axle - leaf sprung type
I need to replace the axle on our 51 FC, it has a straight (not original) mobile home wheel/axle assembly. Our 53 FC with the same frame, wheel well and leaf spring geometry has a dropped axle so it appears either straight or dropped will work. Are there other reasons, besides being closer to the ground, for choosing one or the other?
Thanks, Mark
Aluminumbskull with Led Balloon in Drag
Birch Plywood and Aluminum go together like
Peanut Butter and Chocolate
MarkR is offline   Reply With Quote
Old 06-28-2005, 12:57 PM   #2
Somewhere , Indiana
Talking Choices
Thanks, Mark
Mark,
Both styles of spindle will work with excellent results. The 4” drop spindle does exactly what you state; it lowers the height of the unit. A lot of trailer manufacturers that do car trailers, landscape trailers and the like want the additional drop for equipment loading/unloading.
I think both types of axle are reputable, it simply becomes a matter of choice, at least for most customers.
Regards,
Henry
axleman is offline   Reply With Quote
Old 06-28-2005, 04:56 PM   #3
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Drop axle
It would also lower the center of gravity for the unit making it easier to tow and less of an obsticle for the wind. Either naturally generated or by passing truck.
>>>>>>>>>>>>>>>Action
Duratorque Axle Replacement Andy R Axles 18 03-19-2017 08:54 PM
Airabelle has sprung her door jeanarlene 1969 - 1973 Safari 12 02-06-2011 12:09 PM
Who made my axle? Pahaska Axles 44 07-25-2007 10:08 AM
one or two axle? vallan1980 Airstream Trailer Forums 5 09-17-2002 05:47 PM
Axle Offset Question DanLyle Axles 11 08-28-2002 09:35 AM
