Old 08-23-2003, 10:48 AM   #1
Unhappy Spindle Replacement ?
I have a badly grooved spindle on one axle on my 1999 Safari 25í.
Can the spindle be replaced or do I need a complete axle?
Matt
morrism11111 is offline   Reply With Quote
Old 08-23-2003, 12:48 PM   #2
Matt.
Spindles cannot be replaced.
To do so will destroy the rubber rods, from the cutting and welding heat, rendering the axle useless on one side.
Additionally, it would be near impossible to properly align a new spindle.
Henschen will not replace "any" spindle.
Old 08-23-2003, 06:31 PM   #3
CanoeStream's Avatar
St. Cloud , Minnesota
Help us out....
Matt --
Can you provide additional information to help us understand how to avoid this problem? Do you have insight into how this occurred?
Thank you!
5 meter Langford Nahanni
Water heater replacement Craig Water Heaters, Filters & Pumps 36 12-18-2014 09:13 AM
Sofa/Sleeper replacement 69Ambassador Upholstery, Blinds, Walls & Interior Finishes 0 02-21-2004 07:00 PM
Suburban Furnace Replacement Craig Furnaces, Heaters, Fireplaces & Air Conditioning 3 10-31-2003 01:53 PM
Replacement air bags on the rear suspension? TRAPEZE Airstream Motorhome Forums 1 03-09-2003 08:42 AM
