Old 02-21-2007, 01:51 PM   #1
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Some data on Henschen Axles
I was able to obtain this data from a good source ....
Henschen axles from 1974 and older used rubber rods that were susceptible to failure, because of the composition of the rubber. The composition of the rubber rods was changed in mid 1974 and continues today. While nothing lasts forever this change helped torsion axles to last much longer.
Rubber must be exercised to keep it "alive." Therefore if the torsion axle is under stress, and not used for an extended period, such as 3 or 4 years or so, the rubber rods "will" take a set in that position. When that set takes place, the axle no longer flexes as designed. This usually shows up with the trailer sitting lower to the ground when at rest as compared to a trailer that has been used on a regular basis. It will also show up as a trailer that bottoms out easily and does not cushion the load inside. Things are shaken up! The only fix is replacement. Using the trailer after the axle has taken the set does not bring back the life to the rubber rods. It may help, however the axle will not regain the original flex it had when new. And that applies to everyone's axle brand as charactoristic of the design.
The fix to avoid the problem? Use the trailer every year or so, this will keep the rubber rods "alive and well." And this is the same advise that Wally gave out back in the 50's and 60's for different reason! Get on the road!
>>>>>>>>>>>>>>Action
Old 02-21-2007, 01:55 PM   #2
VAC President
Buttercup's Avatar
1977 27' Overlander
1954 25' Cruiser
1990 34.5' Airstream 345
VC Highlands , Nevada
Send a message via Skype™ to Buttercup
Amen, brother!
Buttercup's Web Site. WBCCI #17330, 11281 & 7830. VAC Past President, TAC NV-2 & NV-3
Buttercup is offline   Reply With Quote
Henschen Axles hex Axles 37 04-15-2005 06:27 AM
How many axles replaced Jabba Axles 7 10-21-2002 01:21 PM
Axles on a Avion 68 Suburban Axles 0 10-06-2002 12:10 AM
Henschen Axle Plant Tour Inland RV Center, In Axles 0 09-22-2002 02:04 PM
Motor Home Tag Axles - winner General Motorhome Topics 0 05-25-2002 04:56 AM
