Old 03-06-2011, 10:51 AM   #1
1977 Argosy Minuet 6.0 Metre
deland , Florida
Should I wait to finish trailer b4 ordering axles
my 66 safari is in need of a new axle. my question is i am doing some custom work on the interior of the trailer and it should be around the same weight as stock but im not 100% sure. should i wait to finish the trailer, weigh it and then order axles? im pulling the frame out in a few weeks to do some welding and new plywood and i would love to do the axle at that time. i was going to go w the dexter 3500lb axle. im almost positive the weight will stay very close to the stock weight of the trailer may differ - + 200 lbs and i think the stoick weight is 3200 pounds for a 66 22 foot safari. am i correct on that?
386kustoms is offline   Reply With Quote
Old 03-06-2011, 10:55 AM   #2
The proper axle rating for a 1966 22 foot Airstream, is either 4500 or 5000 pounds.
I am not at my office to look at the charts, but I will correct the post tomorrow.
Old 03-06-2011, 11:42 AM   #3
Colin H's Avatar
1957 30' Sovereign of the Road
1959 28' Ambassador
1949 24' Limited
Peru , New York
The original dry weight on your trailer was supposed to be 3360 & it has a 5,000 lb axle on it. You are correct, it is much easier to replace the axle when the chassis is off........................even easier when it's upside down
Colin
ID:	123793   Click image for larger version
Colin H is offline   Reply With Quote
Truck & Trailer Weights nickmeloy Towing, Tow Vehicles & Hitches 6 04-02-2014 10:02 AM
How do you deal with your trailer while exploring? mikescha On The Road... 18 02-21-2011 11:36 AM
A sad end to a wonderful trailer rmk110761 Airstream History 9 02-15-2011 09:12 AM
