Old 11-13-2015, 02:50 PM   #1
bvcg1's Avatar
1971 23' Safari
San Antonio , Texas
Shocks or No Shocks?
I received my Dexter Axles today. I ordered them with shock brackets and they arrived without. Should I go ahead and install without the shocks, or should I take them some place locally and have some brackets put on?
What say you?
bvcg1 is offline   Reply With Quote
Old 11-13-2015, 02:54 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Personal opinion. Have the brackets properly mounted. The person I bought my Bambi II axle thru made sure the mounts arrived welded properly on my axle.
MICHAEL
Old 11-13-2015, 04:17 PM   #3
What say you?
Weld the shock brackets on before you install the axle.
I cannot tell who sent you the axles, but if we did, the shock brackets would have been sent separately.
Old 11-13-2015, 08:46 PM   #4
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Got ours rom Andy, InlandRV. I welded my own from Andys kit on. On our 34' Excella, that was about 3" from the axle plate to the location we welded the new plate. You can mount further out so you can have more clearance and may be able to mount your shock after axle install. I could not. So mounted shock to axle before install. This keeps the "shock" parallel... If I have to remove in future I will bend the plate.
Peace and Blessings..
Channing
WBCCI# 30676
Old 11-13-2015, 10:26 PM   #5
Mission , Texas
Shocks ... there is a reason why they were invented and continued to be used.
nrgtrakr is offline   Reply With Quote
Old 11-14-2015, 10:55 AM   #6
JRF0st3r's Avatar
1967 22' Safari
West Fork , Arkansas
Uwe Salwender, Area 63 Productions, advises that shocks on Dexter TorFlex axles are decorative. He has tested with and without shocks and finds no difference. In my opinion if the axle supplier thought you should add shocks they should have welded on the brackets in the right spot prior to shipment. Of course everyone is entitled to their own opinion and should do whatever they think best.
JRF0st3r is offline   Reply With Quote
Old 11-14-2015, 12:17 PM   #7
coloradopete
coloradopete's Avatar
1988 25' Excella
Montrose , Colorado
Shocks or no?
I am the original owner of my 28 year old 25' Excella. Replaced the shocks this year for the first time, with those recommended by Airstream (horizontal mode), and notice a significant difference in the amount of sway and bounce that occurs when someone is walking around in the unit while it is parked. This can only mean there must be considerably more sway and bounce when traveling with no shocks or with those that are too old to function properly. IMHO, it is well worth using shocks to reduce the amount of stress on the trailer that is present without them. I purchased mine from Inland RV.
coloradopete is offline   Reply With Quote
Old 11-14-2015, 02:23 PM   #8
Alphonse's Avatar
2010 28' Flying Cloud
Lower Alabama , USA
Put the dampers on
You need the damping, put the shocks on. Towing is problematic enough without creating an additional issue to contend with.
Alphonse is offline   Reply With Quote
Old 11-14-2015, 04:23 PM   #9
r carl's Avatar
Lin , Ne
Did he use a flat bed trailer for testing?
Old 11-14-2015, 05:46 PM   #10
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
The difference is "night and day"!!! I have new axles and shocks.... Traversing roads that once bounced all over... Now, smooth.
Channing
WBCCI# 30676
Old 11-14-2015, 06:26 PM   #11
1966 24' Tradewind
2005 22' Safari
Bastrop , Texas
Our 22 ft tandem axle Safari came from the factory with no shocks and performs flawlessly :-)
dannydimitt is offline   Reply With Quote
Old 11-18-2015, 02:18 PM   #12
Hittenstiehl's Avatar
1961 28' Ambassador
1961 19' Globetrotter
Mesa , Arizona
We just got new ones and asked for the 32 degree additional lift. Sorry if that verbiage is not quite correct. Being installed as we speak. Old ones and new ones in photograph. Went with Monroe Gas Magnum Shocks.
Lots of threads here on Axles and Shocks. Andy from Inland RV and Colin Hyde great sources and resources.
ID:	252453   Click image for larger version
Hittenstiehl
Hittenstiehl is offline   Reply With Quote
Old 11-18-2015, 02:19 PM   #13
King of the Zebra Speedo
Panama Red's Avatar
Obrien , Florida
I fairly well documented the ever popular "Welding of the Shock Bracket" in my epic, best selling, award winning, thread to end all threads, "Resurrecting Big Bertha; How I Spent $30,000 on a $2,000 trailer"... Pictures and all (to keep it interesting for our north central Florida friends).
I recommend installing them. Someone much smarter than me decided they needed to be there... Now electric brakes on the other hand, there's some weight you can do without! Your truck has brakes! Why bother with them on a trailer?
-Red, not serious about the brakes...
Somebody ought to clean these windows. There is a tremendous buildup of gook all over them...
Panama Red is offline   Reply With Quote
Old 11-18-2015, 03:09 PM   #14
noreen&sal's Avatar
1981 27' Excella II
mays landing , South Jersey
Yeah I hate all those frills. Sal
Sal & Nora
Let us live so that when we die even the undertaker will be sorry. Mark Twain
AIR 42483
TAC N.J. 17
WBCCI 24740
noreen&sal is offline   Reply With Quote
Shocks or no shocks? Thisisliving Shocks 34 07-01-2013 08:59 PM
Shocks, shocks and more shocks Inland RV Center, In Commercial Listings 1 05-26-2009 03:37 PM
Shocks or no shocks with new Dexter Axles? nick6930 Axles 5 04-13-2009 03:41 PM
