Old 04-18-2009, 03:56 PM   #1
blickcd's Avatar
Milford , Ohio
Shocks don't fit with new axles
I just installed some new axles on my 31' 1979 International. These are the Henschens axles with the higher load rating and increased downward angle which raises the ground clearance by about 3 1/2 inches.
Trouble is that the new shocks I got won't fit. Given the position of the shock mounting stud on the frame and the one on the axle, the shock just isn't long enough. Even if it were long enough, given the increased downward angle of the torsion arm, the shock would be rubbing on it just a little.
I know people put these axles on all the time and figure there mush be a solution. Weld or bolt a new mounting stud on the frame? Some sort of adapter? Just return the shocks and live without them?
I bought the goods from Inland RV but thought I would see what answers I could come up with here before calling for tech support.
Christopher
blickcd is offline   Reply With Quote
Old 04-18-2009, 05:38 PM   #2
1960 24' Tradewind
Riverside , California
Install the shocks on the axle shock brackets first and after it's on the ground install the shocks to the frame shock bracket last.
ZoomZoom is offline   Reply With Quote
Old 04-18-2009, 06:10 PM   #3
Mikethefixit's Avatar
1977 27' Overlander
Trotwood , Ohio
Send a message via Yahoo to Mikethefixit
Chris
Ya shoulda brought em up here too the old man and let me install em fer ya. I didn't have a minutes problem wiff mine last fall, 3 hrs an I was done. I did them myself and Im really really OLD.
Like ZoomZOOM said axle end first and then let it down and the angle will change as U put weight on it.
Good Luck
Roger & MaryLou
___________________
F350 CREWCAB SW LONG BED
7.3 liter Power Stroke Diesel
1977 27ft OVERLANDER
KA8LMQ
AIR # 22336 TAC- OH-7
May your roads be straight and smooth and may you always have a tailwind!
Mikethefixit is offline   Reply With Quote
Old 04-21-2009, 06:59 PM   #4
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Riverhead , New York
I had no problem with mine?
'77 Sovereign Intl 31' CB
Shocks or no shocks with new Dexter Axles? nick6930 Axles 5 04-13-2009 03:41 PM
Will 2004 Henschen Axles fit under 1971?? Pschoerrn Axles 15 09-05-2006 06:18 AM
My new axles don't fit DavidsonOverlander Axles 5 11-21-2005 01:13 PM
Bad roads damaging interior!! Axles? shocks? kooblekidz Axles 7 09-05-2005 09:29 AM
