Old 08-20-2019, 02:29 PM   #1
newas4mark's Avatar
1968 30' Sovereign
Rockford , Michigan
Shock absorber mounts for lift kit
I will be adding the Dexter lift kit to my '68 Sovereign. I have the standard shock absorbers and am wondering if I can use the original shock mounts or will I need to weld new ones on? The lift kit will lower my axles +/- 3". What have others done? The instructions that came with the kit do not mention shock absorbers. Click image for larger version
newas4mark is offline   Reply With Quote
Old 08-20-2019, 03:18 PM   #2
Overkill Specialist
GMFL's Avatar
2014 23' International
Dadeville , Alabama
You should be able to use the current ones. I’ve done 4 lifts on Airstreams and on all we used the factory mounts.
Here’s a couple of Blog post
http://www.airforums.com/forums/blog...3fb-lift-3033/
http://www.airforums.com/forums/blog...lift-kit-2901/
Dept of “OverKill”
Old 08-20-2019, 04:56 PM   #3
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
My 2002 Classic had Henschen axles. I replaced the axles with Dexters and had to modify the shock mounts. You didn't mention that you were changing the axles, so there should be no need to modify the mounts. The axle will just be a little lower.
The lift kit is a different question. If you have Dexter axles you should be fine. If not you may have to modify some combination of the trailer, lift kit, or axles. In my case we slotted one hole on the axle bracket when I changed axles. We then had to slot one hole on the lift kit to get it to mate up with the trailer when I added it later.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 08-20-2019, 07:56 PM   #4
newas4mark's Avatar
1968 30' Sovereign
Rockford , Michigan
Al
Al, I have Al-ko Axis axles purchased from Colin Hyde. They are exact replacements for my original axles and I believe they are also identical to Dexters. I also bought my Dexter lift kit from Colin. I was able to use the original shock mounts.
Thanks for your reply.
Mark
Old 08-20-2019, 07:58 PM   #5
newas4mark's Avatar
1968 30' Sovereign
Rockford , Michigan
Thanks GMFL. It’s good to hear that from someone who has installed several of these. I do not weld so that is encouraging.
Thanks for your reply,
Mark
Shock absorber life safari 28 Axles 10 10-13-2009 07:17 AM
Avion shock absorber question ColtSAA45 Vintage Kin 4 07-21-2007 10:18 AM
1969 Safari shock absorber studs tom westlake Axles 6 06-03-2006 12:03 PM
Shock absorber information Nye Thatcher Shocks 0 02-16-2005 10:49 AM
Broken shock absorber stud jasper2222 Axles 7 01-31-2005 06:34 PM
