Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Axles
Old 10-11-2009, 09:05 PM   #1
safari 28's Avatar
Profile:  2004 28' Safari
holland , Michigan
Shock absorber life
Just wondering about the life of the Shock absorbers from the factory. I noticed one has some oil on it, no problems just wondering. i would say mine have about 22k miles on them. Heading west and she is performing perfect.
safari 28 is online now   Reply With Quote
Old 10-11-2009, 09:11 PM   #2
Airslide's Avatar
Profile:  2001 30' Limited
Novato , California
Images: 47
Send a message via Yahoo to Airslide
I was looking at mine and they are gabriels. If these were on a car they would be good for about 25000 miles. I would think its not good for them to just sit either. Most people probably wouldnt worry about it and change them out when you need axles. My trailer is 8 years old now and some would say it needs axles now so maybe i will do it then...
Vin
2001 Airstream 30' S/O 70th Anniversary
1994 F-350 Crew 7.3 IDI Turbo, C6, Dually
Airslide is offline   Reply With Quote
Old 10-11-2009, 09:27 PM   #3
ROBERTSUNRUS's Avatar
Profile:  2005 25' Safari
Lakewood , California
Images: 18
The shocking truth!
Hi, simply put, shock absorbers are shot when all the fluid has leaked out, not traces of seepage; And/or when the dampening effect is no longer there. Remove your shocks and push them in and pull them out [for two way shocks] and if there is little or no resistance, they're shot. Mileage does not determine replacement. [except to the shock salesman]
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
2000 Navigator / Equal-i-zer / P-3
YAMAHA 2400 / AIR #12144
Old 10-12-2009, 07:57 AM   #4
safari 28's Avatar
holland , Michigan
Thanks for the thoughts. Currently running I80 west, and no streamers to blink headlights to. But then again that is normal for us, we travel all winter in Colder climates and most are smarter than we are.
Old 10-12-2009, 08:18 AM   #5
More than one rivet loose
thecatsandi's Avatar
Profile:  2006 31' Classic
Missoula , Montana
Sixty thousand miles or three years which ever comes first. That's how long mine lasted. Then they started leaking. They were replaced early June.
Michelle
Sarah and Snowball
Ruby, (05 BMW R1200RT)
Daisy, (06 Diesel F-250 w/Tow Command)
Butter Cup, (06 Clssc 31 w/dinette, solar) 60,000 miles in 2.7 years.
http://Michelles-Adventures.US
http://frontyard.home.dyndns.org:8181
http://backyard.home.dyndns.org:8282
Old 10-12-2009, 08:31 AM   #6
Well-Preserved
overlander63's Avatar
Profile:  1974 31' Sovereign
The "20,000 mile replacement" started innocently enough, as a suggestion to check your shocks at that time. The theory was it was a good middle of the road number for inspection, to head off problems before they occurred. That number slowly morphed into a marketing tool for shock replacement.
It's a very good idea to look at the shocks when you perform your annual bearing repack/brake inspection (oh great, something else to look at!), If you notice oil seeping from a shock you can probably get one more season's use out of them, at which time you should replace all of the shocks on the trailer. If the shock has a lot of oil on it, or when you remove one end of the shock and try to extend or compress it and fin no resistance, you should replace the shocks as soon as practicable.
Shocks should be replaced in pairs, just like brakes, but remember, they've all been on the trailer the same length of time, and if one leaks today, another may leak next month. (the moral of that story is to replace them all at the same time)
(No Longer at Inland RV)
Old 10-12-2009, 12:44 PM   #7
Commercial Vendor
Profile:  Corona , California
Shocks
Shock absorbers are motion restrictors.
How many times the cylinder moves, dictates their life.
If the running gear was proberly balanced, then the useful life increase.
If the running gear "was not" properly balanced, then the life of the shocks is shortened.
Any signs of leakage, indicated a worn out shock, since a person cannot measure the amount of fluid lost.
Shocks should always be replaced as sets, never one at a time.
Good shocks, along with good torsion axles, help provide the soft ride that an Airstream trailer must have. Those two work together.
Bad shocks, allow greater motions to a bounce, that can cause other problems.
Andy Rogozinski
Inland RV Center
Corona, CA
Inland RV Center, In is online now   Reply With Quote
Old 10-12-2009, 06:23 PM   #8
safari 28's Avatar
holland , Michigan
All good stuff and thank you to all. Sitting in Omaha at a customer location and some do have oil on them. Damn, it is cold.! Andy, could be in your neck of the woods by late November. My best customer is in Corona!!
Old 10-12-2009, 06:34 PM   #9
Commercial Vendor
Lunch, dinner, martunies, er, martini's, ah you know what I mean.
Anyone I might know in Corona?
Andy Rogozinski
Inland RV Center
Corona, CA
Avion shock absorber question ColtSAA45 Vintage Kin 4 07-21-2007 11:18 AM
1969 Safari shock absorber studs tom westlake Axles 6 06-03-2006 01:03 PM
Shock absorber information Nye Thatcher Shocks 0 02-16-2005 11:49 AM
Broken shock absorber stud jasper2222 Axles 7 01-31-2005 07:34 PM
63 TW shock Moonshot Shocks 5 08-26-2002 10:24 AM
