Old 06-28-2010, 06:44 PM   #1
NicheVintage's Avatar
1965 26' Overlander
The Gorgeous Pac Northwest , Washington
Images: 34
Seals? Where to find replacements?
Took the Overlander over to local shop to have the brakes checked out and replaced as well as re-pack of the bearings. I have had great experience with them as good and honest family biz. They called and said that I have the original axles (in good shape) but they can't find new seals for them? Thus they can't do the brakes and re-pack because the previous owner never replaced the seals and all the grease just ran into the brakes! I have 2 wheels that are completely caked in grease, the other two that barely work.
They said that I could replace the axles since I need new brakes anyway but seems a bit overboard unless I would be stupid to think I would get more live out of a 45 year set of axles...
So I need to find seals for original 65' axles. Any ideas? Problem is that I was trying to hit the road on Thursday for a very, very, long trip.
Shawn
NicheVintage is offline   Reply With Quote
Old 06-28-2010, 06:47 PM   #2
Wise Elder
Jammer's Avatar
2010 30' Classic
Are you sure the axles are still good? That would be remarkable.
Old 06-28-2010, 06:53 PM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
If your axles are in good shape you can replace the complete brake assembly for about $50.00 each. That is a lot cheaper than replacing individual parts or having the current brakes cooked free of the grease. Check
Trailer Parts Superstore - Electric Trailer Brake Assemblies
or
REDNECK CAR PARTS USED AUTO PARTS - CAR PARTS & TRUCK PARTS
They will have the seals also.
2004 Excursion 4x4
Old 06-28-2010, 07:03 PM   #4
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
I'm like Jammer, amazed that your axles are good. The ones on my 68 were frozen solid and I had ZERO suspension.
Old 06-28-2010, 07:08 PM   #5
richinny's Avatar
2011 34' Classic
shawn, some of the early axles reportedly have weaker spindles than later years. if you fall into that group, you might want to replace the axles and even go for self adjusting brake shoes. i wish i had more info for you. :-(
Ricky
Old 06-28-2010, 07:44 PM   #6
goransons's Avatar
1963 22' Safari
1955 26' Cruiser Overlander
Yakima Valley , Washington
Send a message via MSN to goransons
I would guess the company that is working on your rig knows a lot about bearings, brakes, etc, but very little about the style of suspension you have. I can't imagine a 45 year old rubber anything being in usable shape. I would really consider replacing the axle, you'll love how it tows, how much easier it will be on the interior and contents of your trailer, and will be using modern brakes, with new bearings, drums and seals that are much more readily available if you ever need parts while on the road. Inland RV (inlandrv.com) would be a good place to start shopping. There are other brands of axles, but you'll have to measure and special order them. If you follow the directions and get the numbers right you might save some money. We've put new axles through inland on both our and 69 and 63. We saved up for both, hated the expense but love the result.
seals, short term try calling Inland also, if anyone knows, Andy will know, that will at least get you by for the trip.
Scott & Megan
VAC LIBRARIAN
Restoring Wally Byam's 1955 26' European Caravan Trailer!
WBCCI 8671
1963 Safari from the 1963-64 Around the World Caravan
goransons is offline   Reply With Quote
Old 06-28-2010, 09:25 PM   #7
check out
It costs nothing to check you axles out yourself, in just a few minutes, and, no tools required other than your eyes.
Read the axle article in the Airstream Central section of this Forums. That will quickly teach you how to check them out.
Once you have that answer, you will know which way to go.
Old 06-28-2010, 09:46 PM   #8
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Ricky,
As I recall, the weak spindles are mainly on 1965 Caravels and other trailers of that length and age, not Overlanders..
Bill
Just my personal opinion
Old 06-30-2010, 11:33 AM   #9
1965 26' Overlander
Images: 34
Thanks to Luke from Luke's Repair and Andy and Inland. Seals ordered and should be back on the road in good shape until new axles are in!
Shawn
Old 07-01-2010, 02:53 PM   #10
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Shawn,
You can get a lot of trailer parts here as well.
Welcome
It's down town and they have a good inventory of trailer parts.
>>>>>>>>>>>>>Action
Old 07-01-2010, 03:31 PM   #11
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Shawn
Hi Shawn,
You made the right decision here. New axles are a must for your 65.
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
http://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Duotherm vs. Suburban Replacements rasmuw Furnaces, Heaters, Fireplaces & Air Conditioning 0 12-05-2007 11:52 AM
'64-65 toilet replacements... 59er Sinks, Showers & Toilets 22 09-04-2007 11:08 AM
ST Tire Replacements LTD93 Tires 4 09-28-2005 04:15 PM
Dometic Frig seals replacements davidlaxson Refrigerators 3 12-08-2003 09:33 AM
Accuslide replacements TBYRNE Airstream Motorhome Forums 3 07-12-2002 06:21 AM
