Old 03-25-2005, 10:50 AM   #1
a.k.a. Ambassador Tim
Safari Tim's Avatar
1960 28' Ambassador
Northern , California
Images: 35
Rusty Nuts
I just ordered up 4 shocks for my Safari.
I also wanted to order eight bolts for the shock mounts. But my bolts are welded on
My worry is they are rusted up pretty well and I don't want to break or strip one out.
I got some Liquid Wrench to start putting on the nuts to help get them off.
I was wondering what is the best stuff to use to get these apart w/o problems?
Any other shock replacement tips are welcome.
Once again, as most things with this trailer, this is new teritory for me
-Tim
theVAP - Airstream Podcast
Old 03-25-2005, 10:58 AM   #2
I have had great results with PB Blaster. But sometimes there is no substitute for concetrated heat - like an acetylene torch.
Of course, this is also a good way to burn up the coach if you do not know how. It is worth thinking about nearby propane lines.
Mark
'85 Sovereign, 25'
Old 03-25-2005, 10:59 AM   #3
Pahaska's Avatar
2014 Interstate Ext. Coach
Hays County , Texas
I found that "Naval Jelly" will remove the rust from the portion of the bolt that protrudes past the nut. I have used the stuff to salvage tools that were dropped outdoors and lay and rusted all winter. It is nasty stuff, so wear gloves.
Heating the nut quite hot with a propane torch will help free it. Heat it, then cool it rapidly several times. That, and some Liquid Wrench will probably do the trick.
John W. Irwin
WBCCI #9632
Old 03-25-2005, 11:16 AM   #4
balrgn's Avatar
1974 27' Overlander
1954 26' Romany Cruiser
1960 26' Overlander
Rockingham County , New Hampshire
Images: 74
Send a message via AIM to balrgn Send a message via Yahoo to balrgn
Steel back then is pretty good grade. the Liquid wrench will most likely do it. If not, heat it up a bit, not red hot, cool it with the liquid wrench. This draws in it into the threads. USE caution, that stuff is very flamable.. If you know wny auto mechanics they deal with stuck fasteners all the time and may have a trick or two...
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'54 Cruiser (Bogart)
'60 Overlander (Hoagy)
WBCCI 1754 - AIR # 6281
www.balrgn.com
balrgn is offline   Reply With Quote
Old 03-25-2005, 11:18 AM   #5
Happycampers's Avatar
1979 30' Argosy
Havelock , where we park it
Like Mark said PB Blaster, that is the best stuff I have ever found, it dosen't work like wd 40, you will need to let it set for several min. for it to have time to weep in if they are bad which I am sure they will be.
Marvin & Annie
Niki (fur baby)
1979 Argosy 30 (Costalotta)
WBCCI 10103
"Happiness is a warm Puppy" Charles Schulz
Happycampers is offline   Reply With Quote
Old 03-25-2005, 11:31 AM   #6
47WeeWind's Avatar
1948 16' Wee Wind
1953 21' Flying Cloud
Denver , Colorado
Images: 20
My worry is they are rusted up pretty well and I don't want to break or strip one out. ... I was wondering what is the best stuff to use to get these apart w/o problems?
Tim:
The absolutely best rust buster is AeroKroil, available by mail order from the manufacturer, Kano Labs. Details can be found here:
http://www.kanolabs.com/
Fred Coldwell, WBCCI #1510, AIR #2675
Denver, Colorado - WBCCI Unit 24
Airstream Life "Old Aluminum"
Airstream Life
"From the Archives"
47WeeWind is offline   Reply With Quote
Old 03-25-2005, 01:43 PM   #7
Safari Tim's Avatar
1960 28' Ambassador
Images: 35
Thanks for the ideas everyone.
Based on Fred's recommendation I ordered the AeroKroil.
Wish me luck!
-Tim
Old 03-25-2005, 02:32 PM   #8
balrgn's Avatar
1974 27' Overlander
1960 26' Overlander
Images: 74
Kroil Rules. Didn't even think of that! Used it in the Machine Shop years back It is by far the best.
www.balrgn.com
Old 03-25-2005, 02:40 PM   #9
As I would want to fit new nuts, I would use a nut splitter to remove the nuts without the possibility of damaging the bolts. Then clean up the bolts, if necessary by using a die, if a wire brush and rust remover doesn't work. The nut splitter is driven by a wrench, and a chisel blade slices across the nut. Ace has one for $12 at http://www.acehardware.com/sm-vpt-pi...i-1290356.html
It's an easy tool to use. Nick.
Nick Crowhurst, Excella 25 1988, Dodge Ram 2500 Cummins Diesel. England in summer, USA in winter.
"The price of freedom is eternal maintenance."
nickcrowhurst is offline   Reply With Quote
Old 03-25-2005, 03:01 PM   #10
1971 29' Ambassador
Leonardtown , Maryland
Rusty Bolts
I have posted this in th past but forgot where.
This is what I would do and have done in the past.
Get a Small hand held "burnsmatic" torch and a candle (any candle). Heat the nuts with the torch until very hot, red if possible. Then put the candle on the threaded part. Repeat this cycle several times. The wax will migrate through the threads and a wrench will loosen the nuts very easily. The wax will flame up when you put the torch on a second and third time. Just keep any flammables away from the work area. If nervous keep a wet rag available.
This works for any rust frozen bolts. Use a wire brush to remove any heavy rust.
_________________
Rebee - WBCCI #1325
2002 Classic Ltd 30'
2007 Dodge 2500, 6.7 Cummins
Rebee is offline   Reply With Quote
Old 03-25-2005, 06:00 PM   #11
Royce's Avatar
1977 Argosy Minuet 6.0 Metre
Colorado Springs , Colorado
I have found Rust Bomb by Conklin works wonders on rusty fasteners. Squirt it on and come back the next day. It has proved indispensable when working on the 55 you see in my avatar. I keept that truck running for over 24 years and never broke or stripped a bolt.
Royce
Royce (K0RKK) 146.460 simplex
Web page http://spearfishcreek.net/
AIR# 3913
'77' Minuet 6 Metre, behind a 2005 stock Jeep Rubicon with Equa-L-Zer hitch.
Royce is offline   Reply With Quote
Old 03-25-2005, 10:11 PM   #12
The only reason I pulled up this thread is because of the title!
I thought, "YIKES!"
Anon is offline   Reply With Quote
Old 03-27-2005, 06:09 PM   #13
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
Lou,
Try out www.trucknutz.com for an added accessory for your Airstream. Note that they also come in chrome but cost more. I'm thinking about stringing a set from one of my axles.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 03-27-2005, 06:19 PM   #14
Royce
Royce,
Can you find Rust Bomb on the Internet?
Lou
Rusty chromed lug nuts nickcrowhurst Wheels, Hubs & Bearings 14 08-02-2004 06:52 AM
BAL stabilizers losing nuts? Kistler Jacks, Stabilizers, Lifting and Leveling 3 04-15-2004 06:50 PM
Am I Nuts? (Shakedown II) keylime 1959-69 Tradewind 14 07-05-2003 08:28 AM
Rusty screws in side windows (galvanized) Orland Dewey Airstream Motorhome Forums 4 06-17-2003 08:42 PM
lug nuts bambi david h Axles 2 02-10-2003 08:59 AM
