Old 04-04-2005, 11:27 AM   #1
Rough Ride
I am getting conflicting info with this problem and am hopeing you all can help clear it up. I have a reese dual cam with 1200 LB spring bars on my 2500HD truck and 28' Excella. I know my tounge weight is probably around 700-750LBS.
The truck and trailer rides and handles great except on rough roads, but get on rough road and it beats you to death. Technical support at reese says with 700-750 LB tounge wt. I should be fine. What do you think? I don"t want to spend another $200.00 to buy 800LB bars and not solve the problem. Is it normal to ride this rough?
CACTUS is offline   Reply With Quote
Old 04-04-2005, 11:56 AM   #2
balrgn's Avatar
1974 27' Overlander
1954 26' Romany Cruiser
1960 26' Overlander
Rockingham County , New Hampshire
Images: 74
Send a message via AIM to balrgn Send a message via Yahoo to balrgn
Originally Posted by CACTUS
I am getting conflicting info on this problem and am hopeing you all can help me out. I own an 05 2500 hd truck and 28' Excella. I have a reese dual cam with 1200 lb bars. My hitch weight should be around 700-750 lbs. Technical support at Reese says this is the combo I need. The ride with this combo is great on good roads, but get on a rough road and it beats you to death. Is this normal or should I, could I get a better ride somehow. I am not excited about spending $200.00 for 800LB spring bars.
Just a thought, do you have too much pre-load on the bars?
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'54 Cruiser (Bogart)
'60 Overlander (Hoagy)
WBCCI 1754 - AIR # 6281
www.balrgn.com
balrgn is offline   Reply With Quote
Old 04-04-2005, 11:56 AM   #3
Coastalview's Avatar
2002 27' Safari
Carmel-by-the-Sea , California
Images: 14
Send a message via AIM to Coastalview Send a message via Yahoo to Coastalview
I'm thinking you should get the 800lbs.spring bars, as the 1,200 lbs. are little to much for your setup.. We run them with our setup, which is similar to yours, but older combination, without creating a drastic change in ride regardless of road surface conditions. Jeff
AIR: 649
TAC: CA-40
Northern California Airstreamers
Coastalview is offline   Reply With Quote
Old 04-04-2005, 03:06 PM   #4
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Rough Ride
Greetings CACTUS!
The Reese technician at the 1998 WBCCI International Rally was the one who identified a similar problem with my 1999 GMC K2500 Suburban/'64 Overlander. I had 1,000 pound bars (actual hitch weight on Overlander is 750 pounds -- gross) -- switched to the lighter bars (would have to check my records, but think that they were rated at 700 pounds). The improvement was dramatic, especially with the performance of the Dual Cam Sway Control -- with my Minuet, I utilize an old pair of 350 pound bars from an old Reese Light-Weight hitch from 1980 (actual hitch weight 525 pounds -- gross). In both cases, the lighter bars perform well with the heavy-duty suspension in my Suburban. I have heavier bars (800 pound for Overlander and 600 pound for Minuet) that I utilize when towing with my Cadillac.
Good luck in solving your weight distribution bar problem!
Kevin
Kevin D. Allen
AIR #827
Old 04-04-2005, 04:52 PM   #5
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
cactus
i have 1000 lb bars on my 29 excella they seem to ride nice with my '00 2500HD.
how much air pressure are you running on your trucks rear axle?
john
you call them ferrets, i call them weasels.
Old 04-05-2005, 07:27 AM   #6
Cactus, I have basically the same set-up as you do ( 2500HD, 30' Classic, Reese 1,200 lb bars) the trailer would beat the HD to "death" on rough roads, especially I-10. After our first trip, I returned to the dealer and told him "this can't be right", he re-measured the clearance of the trailer front and back and determined that the back of the trailer was 2" lower than the front of the trailer, he installed a new Reese drop bar, and that solved the problem.
Bill & Lois Lanio is offline   Reply With Quote
Old 04-05-2005, 02:41 PM   #7
Tires are set at45lbs down from 50 this did not seem to change anything. I have measured ball height on trailer and get one reading when leveling the trailer with a level and a different reading when leveling with tape measure< which should I use? Not much feedback from my use of 1200lb bars, I will weigh tounge this weekend. Airstream says
_630lbs, I figure 700-750.
Old 04-05-2005, 08:24 PM   #8
Tinsel Loaf's Avatar
Solved our rough ride with the commercial air hitch. If you have the cash it will solve your problems.
Tinsel Loaf is offline   Reply With Quote
Old 04-06-2005, 04:58 AM   #9
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
80 psi
cactus
when i have my harley in the back of the truck i run max inflation 80 psi. even then the ride is very nice. without the bike in back i run 55 to 60 psi. i prefer the higher pressure because it prevents tire flex that can amplify sway. tires run cooler too.
try to see if you can get the trailer as level as possible, that should improve the ride. i would skip the level on the trailer and the tape measure. get a 36 inch masons level and put it on the floor in the trailer. this should give you the best reading.
weigh the tounge and let us know what you find!
john
Old 04-06-2005, 06:51 AM   #10
Weighed the trailer tounge last night, it came in at 930 lbs! Manuel said 630lbs. I will be going to the rally in Ga the 15th, so I will set tires at 55 and level the trailer with the level. Thanks to everyone for your help. I will report back on the 18th.
Old 04-19-2005, 09:49 AM   #11
Rough Ride
Learned lots of good stuff at April rally in Ga. After setting tire pressure back up and installing a shorter drop bar(good4") problem solved. Hitch ball on truck is now almost 2" higher than coupling but still able to set up for level trailer with enough load for sway to work and some load (less) on to front of truck.
Thanks to everyone on this forumm and espeachely at the rally for good advice.
Old 04-19-2005, 10:14 PM   #12
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
Cactus,
Glad you got the right combination. I knew that running your load range E tires at the lower pressures was not a good idea and the angle of your drawbar sure looked funny.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
interior polishing and rough curtain track sammamishsafari Upholstery, Blinds, Walls & Interior Finishes 2 06-23-2003 04:03 PM
Velvet Ride spring shackles? Rusty Bucket Our Community 5 12-25-2002 08:30 AM
Very rough finish lenny Cleaning, Stripping & Polishing 9 11-11-2002 05:42 PM
4x4 tow vehicle... or not? Cheryl Tow Vehicles 11 08-22-2002 11:00 PM
