Old 10-19-2015, 07:13 PM   #1
1989 32' Excella
Sharon Springs , New York
Ride height measurement ?
Took our new-to-us 1989 AS to a local welding/repair shop that regularly works on all types of trailers. We intended to have them replace the axles/brakes on our unit. After crawling underneath the trailer the repair person confirmed that the axles were most likely original, the brakes, shocks and hubs appeared newer than the axles and in very good condition. He said he would have no problem replacing the axles but asked why? I explained that the axle systems last approximately 25 years and then start to degrade in performance. He said to run the unit for a couple of years and then when/if the ride height starts to drop then replace. He said ours was in great shape underneath and the axles have life left in them. He told me to measure from the top of the wheel-well to the center of the hub periodically and monitor the ride height. The distance between these two points on our trailer is 11-1/2" hub-center to wheel-well edge with all tires +/- 1/4" of each other. The trailer seems to pull smooth, brakes evenly and doesn't "bounce and sway" much even over our "smooth" New York roads.
Just not sure what the proper or serviceable ride height measurement is. This shop was more than willing to do what I wanted, so I trust them and their advice. Just trying to figure at what point is too low for ride height. Any information on what newer units measure wheel-well to center of hub?
James and Rebecca
Easyrider06 is offline   Reply With Quote
Old 10-19-2015, 07:58 PM   #2
JimGolden's Avatar
1977 31' Excella 500
Check the Down Angles
Well, he might be right. But, you also need to check the down angle on the axle swing arms.
When new, they should angle downward from the horizontal somewhere around 20 degrees. So, the center of the wheel will be lower than where the swing arm hooks on to the end of the axle. It will angle down....
If your swing arms are parallel to the ground, they are worn out.
Also, if you jack the trailer up, and the swing arm doesn't rotate down some so that the wheel is lower than it was, your axle is worn out.
The rubber rods inside them get hard over time, and they lose their springiness. When that happens, it's not cost effective to replace the rubber rods...so most folks just get new axles.
You may get lucky and get a few more years out of them. But it's unusual for them to last that long.
Take care,
- Jim
JimGolden is offline   Reply With Quote
Old 10-19-2015, 08:29 PM   #3
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
I do not believe there is a published spec on ride height measured that way.
>>>>>>>>>>Action
Old 10-19-2015, 08:47 PM   #4
Mission , Texas
How about this ...
http://www.inlandrv.com/articles/dur...xle-92001.html
nrgtrakr is offline   Reply With Quote
Old 10-19-2015, 09:14 PM   #5
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
A few years ago I put on new Dexter axles which were rated at a bit more capacity than OEM. When installed the torsion arm was pretty much horizontal when weighted.
Old 10-19-2015, 09:31 PM   #6
Alumaholic's Avatar
1966 24' Tradewind
Albuquerque , New Mexico
Images: 33
You found a very thoughtful tech, and honest. Find out what kind of beer he drinks, and buy him a case.
There is no 25 year rule on axles. Where you live and how you use them are more important factors than chronological age. There are tons of information on these forums. And pictures. Send us pictures of your Stream taken perpendicular from the long axis, oh about 30 feet away; and we'll tell you if you need axles. That's why we are here.
Ken L
1966 Tradewind 24
2007Chevy Silverado 2500 HD Duramax/Allison
Four Corners Unit WBCCI #8654
Alumaholic is offline   Reply With Quote
Old 10-19-2015, 10:03 PM   #7
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
The rubber rods inside the axle get hard, transmitting more road vibes to the trailer frame. The moving part inside also cannot hold on to the inner rods and may allow misalignment.
Peace and Blessings..
Channing
WBCCI# 30676
Old 10-20-2015, 04:33 AM   #8
1989 32' Excella
Thanks for the responses, will try to upload some pics and see what you all think.
Old 11-18-2015, 02:16 PM   #9
nickclifford's Avatar
1972 31' Sovereign
felton , California
How does this look. Original '72 axles.
Would love to see some before and after pics Click image for larger version
Name:	ImageUploadedByAirstream Forums1447881315.333353.jpg
Wondering what kind of lift to expect with new axles. I'd like as much as possible given the long back end.
Lift kit experience anyone?
nickclifford is offline   Reply With Quote
Old 11-19-2015, 04:06 AM   #10
4RXLA's Avatar
West Sacramento , California
Images: 33
You can expect a 3-4 inch increase in height. The belt line trim should be above the rim of the tire.
4RXLA is offline   Reply With Quote
Old 11-19-2015, 09:34 AM   #11
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Here is the 'original' level
Here is the 'new' level with 32 degree down and 3500# axles
The bottom of the wheel well trim is level with the top of the tires now.
Channing
WBCCI# 30676
Old 11-19-2015, 10:14 PM   #12
1972 31' Sovereign
felton , California
oh, wow! that's a lot of gain, probably all I'd need. Thanks so much for sharing those pics ... would you mind sharing more info? like where did the axles come from? price? any mods needed? or just bolt on? easy for a novice ?! thanks, Nick
Old 11-20-2015, 08:01 AM   #13
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Please, read this thread...
http://www.airforums.com/forums/f437...rs-143529.html
This is NOT a task for the light hearted if ill prepared. In my case, I had 9000#, 4.5 tons, supported off the ground with "only" floor jack stands. Each of mine are rated at 4 tons.. But small base. They were " backed up" by 8 ton jack stands " as redundancy". I used an 8 ton bottle jack to " raise" the AS high enough to "clear tires" off the ground. This made for closer work area underneath, but I didn't have the AS way up in the air as Texas has a way of sudden high wind.. And a "short" fall can have less damage. Just being careful...
When in doubt, ask here...
You will need adequate floor jacks, jack stands, "moving trolleys".. Air tools are nice.. Always work with an accomplice �� You will need a step bit capable of 7/8" or greater or a drill the size of your boots (if you need to redrill for alignment (happened to us) and a drill that can turn it... Or a big drill to turn a big bit.
You may be able to use cribbing in place of floor jack stands... Your choice.
Does this help?
Channing
WBCCI# 30676
Hitch Height vs. Ball Height adamwright Towing, Tow Vehicles & Hitches 5 02-12-2015 03:24 PM
Ride height specification Tony Lee Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 1 04-04-2013 05:27 AM
Ball height measurement from 200 miles away Section8 Hitches, Couplers & Balls 8 01-20-2011 08:12 PM
'57 Flying Cloud ride height Larry in MO Axles 4 09-27-2008 06:35 PM
Proper ride height? guy99 Classic Motorhomes 19 05-19-2006 10:07 PM
