Old 04-28-2003, 10:11 AM   #1
1973 23' Safari
1976 25' Tradewind
1997 25' Safari
Denver , Colorado
Restoring Torsion Arm/Axle Resiliency
My recently purchased 1973 23' Safari only has about 5/8 inch clearance between the front of the right front tire and the wheel well as a result of longterm storage/improper loading. It leans to the right about 2 inches. Is there a way to restore the torsion arm/axel resiliency? It has been suggested that the trailer be jacked up to allow both wheels on the right side to be suspended allowing the torsion memory to be restored. Any Suggestions?
Roadanswer is offline   Reply With Quote
Old 04-28-2003, 11:04 AM   #2
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Open the wallet wide
R,
The amount of tire that shows above the rim to the edge of the wheel well is how much? (Not measuring on the front of the tire, measuring at the top of the rim.)
My guess is it's time for axle replacement. - However, maybe towing the trailer for a distance many times. Bounce it up and down? Jack it up and set it so the tires hang. All of these suggestions are free. -
And what you are attempting to do is take out the SET the rubber torsion springs have taken over many years. Not an easy task since it took years for this to occur in the first place. My guess is in the long run, axle replacement is the only lasting fix.
Let us know what happens. And a pic would be even better.
>>>>>>>>>Action
Action is online now   Reply With Quote
Old 04-28-2003, 02:35 PM   #3
1973 23' Safari
1976 25' Tradewind
1997 25' Safari
Denver , Colorado
Re: Torsion bar/axel
Thanks Action- After talking with Andy at Inland RV I have decided to replace the "axles' which is what I figured I would have to do. Then I've got new brakes etc. and the angle of the new torsion bar will be at 35 degrees allowing much improved ground clearance. P.S. the wheel well, top outside, was even with the top of the rim. Looking at the diagram for a Dura-Torque axle provided with Inland RV's part description, my torsion bar is at a positive angle which indicates replacement is in order.
Old 04-28-2003, 03:12 PM   #4
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
R,
I defer to the title of my reply.
And you will have a nice unit when you are done.
>>>>>>>>>>>>>>>>>>>>>>>>Action
Old 10-02-2009, 01:24 AM   #5
another project's Avatar
1969 31' Sovereign
Gilbert , confusion
actually that would be negative.
Rich
another project is offline   Reply With Quote
Old 10-02-2009, 01:25 AM   #6
1969 31' Sovereign
Gilbert , confusion
wow I just looked at how old this was.
sorry.........
R
Old 10-02-2009, 07:18 AM   #7
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
sorry.........
R
Strangely enough, even though the person that started this thread hasn't posted again since they made the two posts above, they were on the forums as recently as this past March. So they're still around, albeit infrequently, and information, unless it is hopelessly out-of-date, is still of benefit.
Old 10-10-2009, 05:56 PM   #8
1964 22' Safari
1962 28' Ambassador
enosburg , Vermont
Ha, 2003 to 2009 and still no way to fix the damn things. $600.00 'cause of 8 pieces of rubber!
putback is offline   Reply With Quote
Old 10-10-2009, 07:52 PM   #9
Tires on a tow vehicle, at least $600.00, and only for "4".
It's not really the cost of the rubber, it's the cost of getting the correct rubber, in the correct place.
Old 10-11-2009, 06:09 AM   #10
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
At one time one supplier actually would rework the axles by replacing the rubbers for $100. They do not do it anymore. It is our American way of being efficient by making everything a disposable, even if only a small portion of the product is defective. We throw away the good metal axle parts because the rubber has gotten old. We throw away complete computers because a transistor goes bad or the product becomes out dated. It is more cost effective to buy a new computer rather, than upgrade the old one.
Old 10-11-2009, 07:41 AM   #11
Good comment.
According to Henschen, the steel in the "old" axles sent in, was "NOT" always in good shape.
They state that the metal tube, internally, many times, was found to have an adequate amount of rust, that in their opinion, jeopardized the strength of the square tube. That in itself, creates a huge liability, if they reworked the axle, and for any reason, the tube failed.
The causes of the rust were numerous, including being near salt water for years.
Today, older Airstream's, have become a "gotta have one" for many people, most of which have fun doing a rebuild. Who knows how many different owners were involved over the course of years, or what they did with the trailer.
Therefore it became difficult for Henschen to call someone and inform them that the inner tube, in their opinion, was not in satisfactory condition, to allow them to replace the rubber rods. They state that the conversations would go "on and on" with the disappointed owner, who now was stuck with freight as well, since the old axle could not be rebuilt.
Law suits being what they are today, dictated to Henschen, to "discontinue" the axle rebuild program, which they did, several years ago.
Henschen is a manufacturer, and, as such, removed themselves from being a "rebuilder".
Henschen's, largest customers, by far, have been the agricultural industries. Airstream, was a very small percentage of their sales, even during the "heydays".
The decisions a manufacturer, of most anything, must make, is not always appealing with consumers, especially when the question of liability, is at the top of the question list.
Old 10-11-2009, 07:58 AM   #12
Mikethefixit's Avatar
1977 27' Overlander
Trotwood , Ohio
Send a message via Yahoo to Mikethefixit
Thats excatly the answers I got when I asked the question when I picked up my new axles at Henshen Last yr. It all comes down to the reworking company's liability. Because of the Ambulance chasin Lawyers out there and those that will sue for Rain Drops fallin' on their head,if they could.
So they just don't do it any more. ANDY's answer is Correct
Roger & MaryLou
___________________
F350 CREWCAB SW LONG BED
7.3 liter Power Stroke Diesel
1977 27ft OVERLANDER
KA8LMQ
AIR # 22336 TAC- OH-7
May your roads be straight and smooth and may you always have a tailwind!
Mikethefixit is offline   Reply With Quote
Torsion axles Silvertwinkie Axles 4 01-29-2004 08:18 AM
restoring 1969 Land Yacht jardiel General Interior Topics 1 08-12-2003 11:33 AM
Restoring Bathroom on '76 Argosy coolerow Sinks, Showers & Toilets 4 03-09-2003 01:14 PM
Restoring vintage A/s's.. for love or money? Rog0525 Our Community 4 02-24-2003 07:36 AM
aluminum restoring rdm Cleaning, Stripping & Polishing 1 02-27-2002 11:37 AM
