Old 03-25-2012, 04:10 PM   #1
silverwoman's Avatar
Scottsdale , Arizona
Restore or replace leaf spring axle?
You can tell me I'm premature for asking this before I have inspected my 1950 leaf spring axle and posting photos when asking a question and I would have to say I agree & I apologise for my impatience BUT...I would like an opinion to know what I might be looking forward to.
I have a single axle, leaf spring. My trailer is steel & I have no idea what it weighs. I will know if I am doing a body off restoration next weekend when I move my trailer to her new home to start the restoration. If you only have 1 axle, it needs to be good and strong. I've looked at the posts regarding torsion versus leaf spring. I've located a dealer & reasonable price for a Dexter axle - just in case I need to replace it. What weight & type axle? What brake 12"? What other recommendations can anyone give me? Do I replace the axle when the body is on? Or when I pull the trailer out to restore it if I need to do a body off restoration?
Trailer Geek
'70 Streamline Duchess
Toyota Sequoia SR5
'58 Shasta Canned Ham
silverwoman is offline   Reply With Quote
Old 03-25-2012, 04:23 PM   #2
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Three choices and considerations. A spring mount can have the axle above or below the springs using the original solid axle. Some of the old trailers ride way to low for comfort...going over bumps and entry curbs at service stations for example. There is nothing wrong with the springs...clean 'em up and lube them. (they have zerks that many folks forget about.) Then consider the brakes. You will most likely rebuild the brakes and bearings completely if you keep the spring axle....just from age. If you go with a new axle get it with the backing plates, brakes and bearings already installed. The mess with figuring out the mounting and finding someone to do a good job of it. You can also just buy a complete axle assembly and mount it above or below the springs in place of the old solid axle.
http://www.southwestwheel.com/store/...erpartcom.aspx
Old 03-25-2012, 04:27 PM   #3
Sodbust's Avatar
1972 27' Overlander
Penokee , Kansas
If it's not broke,, don't fix it..
First I would not worry about switching axles until you see if anything is broke..
The main reason its an issue with AS and torsion axles is once the rubber is hammered out,, there shot.. No spring action left..
Leaf springs are a proven concept.. If all the leaves are not broken,, and have equal arch,, at worst it might take some new spring eye bushings to restore.. Some are brass and others are rubber..
Spindle condition is another area once you pull the hubs for a clean up.. If the spindles look good and has never spun a bearing and the threads are good on the end its nothing more than clean it all up and inspect the bearings and if not showing ware or chips,, repack, replace the hub seal and go another 20,000 miles..
Brakes are matched in size with the axle payload.. If you have a 4500 lb axle your brakes will handle stopping 4500 lbs.. Double axle trailers might only have 2500 lb rated axles, and the brakes a lot smaller but have 4 of them all holding back the rated load.
First things first.. Don't get too far ahead of yourself.
Sodbust
Sodbust is offline   Reply With Quote
Old 03-25-2012, 04:31 PM   #4
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
I replaced the original 4 inch drop axle on a 54 Safari I had. The original axle was quite useable, however the trailer was very low to the ground and also had Warner electric brakes which is long out of the business.
I replaced with a Dexter straight axle, 5200 lb rating with 12 inch brakes and the standard 6 bolt wheel pattern.
I did retain the original springs so the "ride" was actually determined by the springs, not the axle rating.
This raised the trailer 4 inches, got me modern brakes, and the cost was partially offset by not having to buy a long drop hitch bar.
I did have to make new spring bushings from Nylon as the old ones were about gone
All in all it worked out quite well.
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 03-28-2012, 04:21 PM   #5
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Welcome to the shiney world of Airstreams!
I believe the purpose of Airstream going to a torsion axle was multifold. It lowered the trailer body. In that lowering process it was smaller assembly that the coach had to be built around. (More interior space) And it provided a softer ride so the insides would be disturbed less.
With that said there are some benefits to leave springs.
Much longer service life
Less money to build
Less money to replace
A little bit more maintence
It will take far more abuse and neglect than a torsion axle.
Changing designs on an existing unit isn't impossible .... given enough time and money. And it will take you way more time and way more money than if you just stick with the original design.
If it were me, I would get a new set of leaf springs, if you even need a new set. There are several shops in Phoenix and may be one in Mesa as well. This would be my approach as it would be EZ and cheap. Which is one of my favorite combos.
>>>>>>>>>>Action
Old 03-28-2012, 04:45 PM   #6
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
I have used this shop (several years ago) to fix a spring problem I had in a truck. Dunbar Spring
They are located in downtown Phoenix and can make new leaf springs for anything.
Richard
Old 03-28-2012, 05:00 PM   #7
Wise Elder
Jammer's Avatar
2010 30' Classic
In general there is no reason to replace the leaf springs unless they are broken. It may be necessary to replace the shackles and bushings due to wear. If they do require replacement it will be cheaper to replace them with leaf springs than with torsion axles. If the spindles are shot or the brake mounts incompatible with new brakes this should be able to be addressed without replacing the springs.
If your trailer was not designed around torsion axles then the only benefit they offer is improved ride. You will have to decide whether it's worth the added costs bearing in mind that a swap from one type to another will require careful consideration of any needed frame reinforcements and also ride height.
Old 03-29-2012, 08:33 PM   #8
The referral to the downtown Phoenix shop I'll save, thanks. I called a good shop near me & they said the don't rebuild these axles because they can get the parts. I thought that was odd. I have some good sites in mind to try to order parts if we need them to do the work ourselves although I wanted a price on having it done for me. And the price for a new Dexter axle with 12" brake & all the other goodies is surprising reasonable. I saw a photo of a 48 restoration where the axle was original rust & all. They didn't even rebuild it for a full restoration so I guess if the axle doesn't need anything it's fine to leave it & clean up & epoxy prime & paint treat the trailer. I'll be able to inspect the axle & trailer this weekend so instead of speculating I'll be able to send photos when I ask questions. I hope I can find what I need to keep my 1950 axles. thanks
Trailer Geek
Toyota Sequoia SR5
Towing Question- 2012 Touareg TDI- Airstreams in general or 2011 Flying Cloud 23fb Roger L Towing, Tow Vehicles & Hitches 21 05-17-2014 07:32 AM
NorCal : NorCal Spring Rally, Casini Ranch, April 13-15, 2012 Coastalview Forum Rallies & Meet Ups 940 10-22-2012 06:03 AM
Repairing or rebuilding Tambour cabinets? lewishw Cabinets, Counter Tops & Furnishings 19 04-01-2012 07:59 AM
new or used... mack-in-nc Dollars & Cents 2 03-25-2012 10:34 AM
What/How to replace Univolt? ovrteakettle Batteries, Univolts, Converters & Inverters 3 03-25-2012 07:34 AM
