06-24-2014, 10:44 AM
#21
1972 31' Sovereign
1975 31' Excella 500
Benton
, Arkansas
I imagine there are instances where a cutting torch would be the preferred method, but man, impact wrenches have gotten impressive over the past years. I just bought a 3/8" unit that will develops 370 foot pounds of breakaway torque.
1/2" units are now able to develop in excess of 1,000 ft lbs.
06-26-2014, 12:40 AM
#22
1967 17' Caravel
1968 24' Tradewind
Northborough
, Massachusetts
Just a quick note to let you all know that the axles arrived on 6/25. That's just two weeks from time of order with Inland. Very quick.
Now comes the hard part.
Thank you.
Planning the next trip....
New England Unit....in Fun, Fellowship and Adventure.
06-26-2014, 01:06 AM
#23
1972 31' Sovereign
Benton
, Arkansas
Changing axles isn't hard, i think you may be pleasantly surprised at how easy it is.
Good luck!
08-28-2014, 06:04 PM
#24
1986 32' Excella
Canton
, Georgia
Pam, how are your new axles? How was e installation? How was the price? We are getting ready to do axles on Our own 1968 Tradewind, just like yours, and would appreciate the information. We have done 80's excella axles in the past.
08-28-2014, 06:15 PM
#25
1976 31' Sovereign
Oswego
I ordered my axles From Colin told him yr. and size, simple bolt up no mods. or welding or drilling, slipped rite in except forgot to put shocks on 1st axle before mounting, had to drop install shocks took about 20 min. no mistake second axle. I did mine when I was over 77 yrs. old, now 80 would not be afraid to do it again, but it helps to have many tools & lots of mech. savvy
08-28-2014, 06:21 PM
#26
1976 23' Safari
1962 22' Safari
1961 16' Bambi
Philly burbs
, PA
Colin!
08-28-2014, 10:18 PM
#27
Moderator dude
1966 26' Overlander
Phoenix
Originally Posted by featherbedder
I ordered my axles From Colin told him yr. and size, simple bolt up no mods. or welding or drilling, slipped rite in .....
There may be a difference in post 1969 units to pre-1969 units.
Typically the drilling or modifications may be needed on earlier units.
>>>>>>>>>>>>>Action
08-29-2014, 02:26 AM
#28
Baltimore
, Maryland
>>>>>>>>>>>>>Action
Very few units are simple "bolt up" no matter who you order them from. There are a few years who get lucky and set the expectation that they all should. I change a number of axles per month, across a wide range of years, rarely do the I get lucky and just unbolt and re bolt.
08-29-2014, 08:46 AM
#29
Corona
>>>>>>>>>>>>>Action
The axle mounting bracket was changed so that the trailer would be one inch higher with the new style, starting with the 1969 models.
Retro fitting then on a 1968 and older, requires new mounting holes.
Not a biggie.
Andy.
08-29-2014, 09:21 AM
#30
1972 31' Sovereign
Benton
, Arkansas
I thought about this a little bit.
My guess is that when the trailers were built they put the axles in the frame slots and drilled the frame to fit the axles.
08-29-2014, 09:49 AM
#31
Corona
The axle mounting plates that are welded on to the side of the frame, already have the axle bolt holes in place.
No drilling is necessary.
08-29-2014, 10:29 AM
#32
1972 31' Sovereign
Benton
, Arkansas
Got ya!
I was just thinking out loud,,, wrongly..
02-21-2015, 03:57 PM
#33
1972 31' Excella 500
Mount Vernon
, Is For Lovers
I ordered mine from Colin,after a SNAFU with "another" retailer in Ca. and they were a direct bolt in replacement with no problems.'72 Excella 500 tandem
02-21-2015, 05:19 PM
#34
Baltimore
, Maryland
You should be very happy for yourself. In my experience, rarely is a simple bolt on. I do a pair or two replacements every month and it has been a long while since this blind squirrel found it's acorn. I need to start doing more 70's trailers I guess.
