Old 06-13-2014, 11:49 AM   #15
WBCCI 8562
Jim in Pima's Avatar
1975 31' Sovereign
Pelzer , South Carolina
Just a tip on changing the axles, I was 70 when I did mine and had a 60 year old neighbor help. We could not get the old nuts to move, called inland, talked to a tech, he said drill a 1/4 hole in the side of the nut, it works, nut cracks and comes right off. Used a floor jack to remove/install axles, worked
great. Biggest problem was swinging the torque wrench under the camper, we were on earth so had to dig some holes to get 140 ft lbs. One of us pulled on the wrench while the other pushed it with his feet, til we heard the click!!! LOL
Jim in Pima Az, enjoying our 1975 31 ft Airstream Sovereign
Jim in Pima is offline   Reply With Quote
Old 06-22-2014, 09:39 PM   #16
Jim Lee's Avatar
1978 31' Sovereign
1984 31' Excella
Springfield , Missouri
Images: 125
I was 65 when I changed mine out on our 78 Sovereign 31', I got my 35 year old nephew to do all the heavy lifting.
It took us about 8 hours from start to finish over two days. Day 1 we got the axles out and the rear one installed, day 2 did the front axle.
I was worried about alignment and shock supports etc. I could have saved myself a lot of worry. It was a relatively straight forward, bolt on, bolt off procedure.
I was glad I had George to help, I don't have that upper body strength anymore to bust those nuts loose.
I got axles from Inland RV, drop shipped to redneck here in SGF.
I am very satisfied with the service I got from Inland.
We changed one axle at a time, rolling the trailer up on two of those things used to change dual axle trailer tires. I did not want to have the trailer sitting on jack stands with george and I under it. I knew a guy who did that ..... RIP friend. Worst part was his son was helping him when the jack stand failed.
Anyhow, trailer rides about 3" higher and has a more aggressive stance. The old axles were flat or had negative angle. George scrapped them out and got 35
bucks for them. I gave George $160 for helping me and he was worth it.
I took the trailer out for a loop around SGF and it seems to pull just fine. I was able to raise my hitch head also which elimates the scraping when I pull in the driveway.
Jim Lee is offline   Reply With Quote
Old 06-22-2014, 09:59 PM   #17
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Replacement Axle source?
Two words,,,,,,
"Impact wrench"
Seriously, it makes dealing with those bolts a lot easier.
Old 06-22-2014, 10:46 PM   #18
1970 27' Overlander
1970 21' Globetrotter
Hamilton , Montana
When ordering make sure the bolt hole pattern is the same on the new as the old.
gdod25 is offline   Reply With Quote
Old 06-24-2014, 08:34 AM   #19
Jim Lee's Avatar
1978 31' Sovereign
1984 31' Excella
Images: 125
Originally Posted by J. Morgan View Post
Two words,,,,,,
"Impact wrench"
The impact wrench I had wasn't strong enough to bust loose the bolts holding the axle to the frame. They'd been on there since 1978. lol
Old 06-24-2014, 08:43 AM   #20
DanB's Avatar
1970 23' Safari
2005 30' Classic
1986 31' Sovereign
Lorain , Ohio
Two more words: Flame Wrench.
And more importantly: Six words: Friend that knows what he is doing.
DanB
________________________________
Proud Member of the Wally Byam Airstream Club #24260
www.campnova.com
The “Ohio Airstreamer -- Informal forum for weekend camping” thread.
DanB is offline   Reply With Quote
Old 06-24-2014, 10:44 AM   #21
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
I imagine there are instances where a cutting torch would be the preferred method, but man, impact wrenches have gotten impressive over the past years. I just bought a 3/8" unit that will develops 370 foot pounds of breakaway torque.
1/2" units are now able to develop in excess of 1,000 ft lbs.
Old 06-26-2014, 12:40 AM   #22
Pam
Pam's Avatar
1967 17' Caravel
1968 24' Tradewind
Northborough , Massachusetts
Just a quick note to let you all know that the axles arrived on 6/25. That's just two weeks from time of order with Inland. Very quick.
Now comes the hard part.
Thank you.
Planning the next trip....
New England Unit....in Fun, Fellowship and Adventure.
Pam is offline   Reply With Quote
Old 06-26-2014, 01:06 AM   #23
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
Changing axles isn't hard, i think you may be pleasantly surprised at how easy it is.
Good luck!
Old 08-28-2014, 06:04 PM   #24
Skatiero's Avatar
1986 32' Excella
Canton , Georgia
Pam, how are your new axles? How was e installation? How was the price? We are getting ready to do axles on Our own 1968 Tradewind, just like yours, and would appreciate the information. We have done 80's excella axles in the past.
Skatiero is offline   Reply With Quote
Old 08-28-2014, 06:15 PM   #25
1976 31' Sovereign
Oswego , Illinois
I ordered my axles From Colin told him yr. and size, simple bolt up no mods. or welding or drilling, slipped rite in except forgot to put shocks on 1st axle before mounting, had to drop install shocks took about 20 min. no mistake second axle. I did mine when I was over 77 yrs. old, now 80 would not be afraid to do it again, but it helps to have many tools & lots of mech. savvy
Old 08-28-2014, 06:21 PM   #26
surfpod's Avatar
1976 23' Safari
1962 22' Safari
1961 16' Bambi
Philly burbs , PA
Colin!
surfpod is offline   Reply With Quote
Old 08-28-2014, 10:18 PM   #27
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Originally Posted by featherbedder View Post
I ordered my axles From Colin told him yr. and size, simple bolt up no mods. or welding or drilling, slipped rite in .....
There may be a difference in post 1969 units to pre-1969 units.
Typically the drilling or modifications may be needed on earlier units.
>>>>>>>>>>>>>Action
Old 08-29-2014, 02:26 AM   #28
Baltimore , Maryland
>>>>>>>>>>>>>Action
Very few units are simple "bolt up" no matter who you order them from. There are a few years who get lucky and set the expectation that they all should. I change a number of axles per month, across a wide range of years, rarely do the I get lucky and just unbolt and re bolt.
'68 Safari axle source DFlores Axles 3 06-05-2012 07:09 AM
An axle is an axle is an axle? Globie64 Axles 45 01-01-2012 01:25 PM
Anyone know a source for replacement naugahyde folding doors? GStephens General Interior Topics 2 05-21-2004 11:25 AM
Do you know of a source for replacement mattresses? Dave Jenkins General Interior Topics 15 03-08-2004 09:22 PM
frame replacement source cherring On The Road... 2 09-27-2003 05:25 PM
