Old 01-05-2003, 09:27 AM   #1
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
High Springs , Florida
Images: 36
Replace Wheel Bearings?
The first hub I pulled, had what appeared to be broken down grease inside of it. The grease was very dirty, and it's viscocity was that of a thick, sludgey motor oil. The bearings and races look fine, no scoring, but seem to have horizontal play. I think I will go up to NAPA with the old bearings and compare to new ones before I decide.
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 01-05-2003, 09:49 AM   #2
BobbyW's Avatar
1965 20' Globetrotter
Houston , Texas
Replacement now for a few dollars is cheap insurance.
And you already have it apart. Its a whole lot easier to do it now than on the shoulder of a road in the middle of summer. Then you know exactly how old they are.
And don't forget to change the seal, even if you don't replace the bearings. You might also have the drums turned while you have them off.
And if NAPA does not have the right size, any good utility trailer parts center will have them.
-BobbyW
BobbyW
AIR# 123
-"You want to make it two inches - or, if you're working in centimeters, make sure it's enough centimeters for two inches."-Red Green
BobbyW is offline   Reply With Quote
Old 01-05-2003, 10:18 AM   #3
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
races?
pick,
are you gonna change the races too?
john
Old 01-05-2003, 10:36 AM   #4
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
fyi
pick
here is a page from timken's tech tips....
http://www.timken.com/products/beari...Fs/Vol7No2.pdf
john
p.s. there is lots of other good info in there too.
Old 02-28-2003, 11:14 AM   #5
Still Working
smily's Avatar
1994 36' Classic 36
North Charleston , South Carolina
part number
does anyone have a P/N for wheel bearings?
1979 Sovereign.
Smily
smily is offline   Reply With Quote
Old 02-28-2003, 02:05 PM   #6
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
Images: 36
I opted not to replace my bearings, after placing them side by side with a new set at the parts store. I could not tell any difference in the appearance, or play between the two. Parts man concured with my decision. Call me crazy if you want to!
Smiley, I get those numbers to you tonight! I wrote them down in the shop.
ARS WA8ZYT
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 02-28-2003, 07:30 PM   #7
Still Working
smily's Avatar
1994 36' Classic 36
32 dollar no holler
Bought a set just in case today, whew! 32 dollars from NAPA.
I went lookin for the return spring, had to order it after checking with four different part stores. 4 dollars apiece.
finish those wheels tommorrow.
Smily
'66 Tradewind wheel bearing size? dreamqueen 1959-69 Tradewind 1 02-18-2004 07:13 PM
Wheel Bearings for a '74 Overlander AV8 Axles 5 02-03-2004 11:42 AM
need to replace the wheel...are there jacking points? 60traveler Jacks, Stabilizers, Lifting and Leveling 1 06-25-2003 04:05 PM
repacking the Wheel Bearings Chuck Axles 26 04-27-2003 09:59 PM
Wheel Hub Temperature 74Tradewind Axles 4 07-23-2002 08:26 PM
