Old 03-27-2011, 09:24 AM   #1
1969 27' Overlander
Kimmell , Indiana
Replace the rubber in the axle?
Is it possible to replace the rubber in the axle rather than replacing the whole assembly?
Hoosierdaddy is offline   Reply With Quote
Old 03-27-2011, 09:29 AM   #2
x
XXXX , XXXX
Not unless you happen to have liquid nitrogen on hand to freeze the rubber into place and the jigs to set up the rubber in the first place. The rubber rods are placed into a jig and distorted (twisted) then frozen with liquid nitrogen. Once the rods are removed from the jig while still frozen you have about 30 seconds to get them into the axle before they thaw out and untwist. I suspect that buying the nitrogen would be far more money than new axles.
wasagachris is offline   Reply With Quote
Old 03-27-2011, 09:48 AM   #3
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Top
Yes it is possible. I just don't think any of the axle manufacturers will do it. You are only an hour from Elkhart where there are Axis, Dexter and Al-Ko Kober. I read that Axis USED to rebuild axles. I'm not sure if that is true or not. I'd want everything all new.
Lance
Top is offline   Reply With Quote
Old 03-27-2011, 11:39 AM   #4
CanoeStream's Avatar
St. Cloud , Minnesota
I've read that the liability issues led to them not doing this any more.
5 meter Langford Nahanni
Old 03-27-2011, 12:03 PM   #5
Liability issues is why Henschen quit the rebuilding program, many years ago.
The inside of the steel tube, can and does get rusty, that cannot be seen. That happens to all torsion axles, no matter who the manufacturer may be.
Obviously, the rust weakens the steel tube. To what degree, is anyones guess.
Then there is the typical round trip freight, that in itself, can out price the cost of a new axle. Individuals do not get freight discounts, that companies do. Prior to a discount, the price to ship a bare axle cross country, can easily cost $1000.00.
Video - Successful Axle Job on 1964 Safari JitneyBead Axles 10 05-21-2012 09:07 AM
Axle weights limits vs. combined weight - What am I missing? Section8 Towing, Tow Vehicles & Hitches 25 02-15-2011 07:46 PM
To replace or not to replace the axles airstrmkids Axles 17 01-13-2011 06:20 AM
