Old 04-25-2007, 07:36 PM   #1
michaelsessa's Avatar
1965 24' Tradewind
san francisco , California
replace bearing?
I have recently purchased a 1965 tradewind that's been sitting for a couple of years do any of you guys know the part # for the bearings?
Mike
michaelsessa is offline   Reply With Quote
Old 04-25-2007, 07:52 PM   #2
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Do you know that the bearings need replaced or are you just speculating due to age? I'd think they've been replaced at some point already. Maybe have them checked.... you could get lucky and they only need repacked.
Old 04-25-2007, 10:44 PM   #3
Desert Fox
1985 31' Sovereign
Tucson , Arizona
Talking Hi Mike
Most bearings have a part number stamped on them . If you are doing the job your self take a sample to a local bearing house. Do not forget to replace the seals.
Regards Russell in sunny Tucson Az.
RUSSELL is offline   Reply With Quote
Old 04-26-2007, 01:37 PM   #4
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
If you are doing this as a PM, you might want to spend your $ on something else, unless there are issues. Check the races in the hub. If there are no issues I would repack and install a new seal.
Wheel Bearing Maintenance
Save your money when you can and spend it for things it will need. And I bet it will need things.
>>>>>>>>>>>>>>>>>Action
Old 04-26-2007, 09:28 PM   #5
1965 24' Tradewind
bearings look good thanks!
repacked the bearings I think I'm ready to roll to seattle....
thanks everyone this is a great site!
Mike (in S.F.)
Old 04-27-2007, 12:54 PM   #6
Mike (in S.F.)
Did you replace the grease seals?
That is a "must" unless you like to take chances.
Repair or Replace Original Bowen Water Heater? Andy R Water Heaters, Filters & Pumps 8 11-16-2005 03:51 PM
need to replace a radiator cap stuart1 Mechanics Corner - Engines, Transmission & More... 1 10-28-2002 02:12 PM
Wheel Bearing seals!!! niftypkg Axles 1 07-30-2002 03:35 PM
Replace copper water lines in '61 Bambi 61BambiCanada Fresh Water Systems 1 05-22-2002 06:04 AM
What tires to replace with? Charcigar Tires 1 04-09-2002 01:08 PM
